Been a while.
I guess I fell asleep for a long time.
Just woke up:
..or maybe THAT was a dream, and I'm still asleep...
..or I'm dreaming I'm having a dream, where I woke up..
….NUUUUUUUUUUUUUUUUUUUUUUUUUUrse: give me my pink pills....NOW !
__________________________________________________________________
Again: thanks for all your advise concerning the crank-shaft,
but again: doing those rather sophisticated modifications just won't happen.
For several reasons, but most importantly; it's way way beyond my scope
and having someone make it is way way beyond my financial means.
Since I last posted I've had a few conversations with people generally
accepted to be the ones in-the-know when it comes to Nimbus engines.
...the guy who runs the Nimbus shop here in Copenhagen
...a Swedish guy ( more later ) who is known as probably one of a few
persons with the most comprehensive knowledge on things Nimbus-technical
...a guy from Vermont, USA (!) ( more later ) who is a brilliant engineer
and probably the other person with the most comprehensive knowledge on
things Nimbus-technical.
They all say that I should stop worrying about it. The crank is immensely strong.
Check it, have it magna-flux tested for cracks... run it !
Perhaps those drag racers who rode Nimbi might have a solution worked out?
Mmmmm: I'm afraid not.
No one has ever tuned a Nimbus to run it in anger on the drag-strip.
If you refer to the one running the strip on the video I posted,
then that one is just an ordinary Nimbus having a bit of fun.
They have been used for racing, but that was back in the forties/fifties
and not because they were suited for racing, but simply because these machines
were the only ones available.
…....but attempts to 'tune' them have been made:
...the Police used 'higher' pistons to ad compression, and speed up things
...apparently some crank-shafts with longer stroke were made.
Something I can't do btw. as it would bring me over the 750cc limit
...some made a cylinder-head/intake modification so as to
sport two carbs ( instead of one )
but the resulting power-gain is debatable. I did however get a message from one who runs it
and he reguraly takes his bike up to 140 km/h ( 87 mph ), which is not bad at all for the old
bumble-bee.
...then there's this one. Now that's quite exciting:
Unfortunately I can't find any information on it, but I'm working on it.
Would be interesting to hear about his experience.
One other 'racing' Nimbus is this one, about which I know nothing,
but a friend is working on getting in touch with the owner
( in Switzerland ).
Now turn up the volume on your PC, and listen to this.
It has a non-original carb, looks like a Mikuni flat-slide (?) and
it stumbles a bit first off, but listen as it leaves the second curve.
CLICK:
http://youtu.be/g-I38mZmZNk?t=2m56sThat, to me, sounds pretty darn sweeeeeet !
