Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Calendar
Login
Register
Landracing Forum
Tech Information
Technical Discussion
(Moderator:
Straight water, water & water wetter, or regular coolant mix in radiator?
« previous
next »
Pages:
1
2
Go Down
Author
Topic: Straight water, water & water wetter, or regular coolant mix in radiator? (Read 9126 times)
Re: Straight water, water & water wetter, or regular coolant mix in radiator?
Reply #15 on:
August 21, 2013, 02:15:14 PM »
In my opinion you are on the right track with Distilled water----has no minerals that can "ceramic" with heat I only run Distilled water when racing and drain.
Miss LIBERTY, changing T.K.I. to noise, dust, rust, BLUE HATS & hopefully not scrap!!
"Security is mostly a superstition. It does not exist in nature, nor do the children of men as a whole experience it. Avoiding danger is no safer in the long run than outright exposure. Life is either a daring adventure or nothing." Helen Keller
John Burk
Reply #16 on:
August 21, 2013, 02:40:40 PM »
The site below says as a liquid (not spray) the flash and flame point of 100% ethylene glycol is about 255 deg. F and that the flash & flame point of 25% EG / 75% water is only slightly higher , 288 and 296 deg. F . The low % doesn't sound all that safe but others can interpret it that better than me .
http://www.google.com/url?sa=t&rct=j&q=%22ethylene%20glycol%22%20water%20flammability&source=web&cd=2&cad=rja&ved=0CDAQFjAB&url=http%3A%2F%2Fwww.reifire.net%2Ftext%2Fethylene.pdf&ei=O_8UUqiVBqWEygHVsIGIBw&usg=AFQjCNG7Dd6-kT1HSm5oRrGub0V3hNpstQ
Pages:
1
2
Go Up
« previous
next »
Landracing Forum
Tech Information
(Moderator:
