Thanks for your comments guys. Stainless, that's just what I'm up to now, getting the nose down as low as it can go. Just hoping when it gets there I'm not looking at 4 or 5 degrees - assuming that's likely too much. If so, don't think I have enough tire clearance to use lowering blocks. Should get this all settled by Sunday. Yes, still got the torsion bars.
Sid, I've got the 170 ci slant bored out to a whopping 174 ci. Got the usual cam, carb, headers, valves, etc., and some extensive head work. Combustion chambers were welded in to get 30cc chambers, milling and porting, 13:1 compression. Engine dyno made 252 hp @ 6,800. Final bit is to get the nose down and aligned. I hope to go fast, but do want the wheels to stay on the ground.
