Author Topic: Need 4 inch wide wheels 15 inch diameter five hole 4.5 circle offset inward  (Read 10936 times)
Offline 8
try 1990s mustang spare tire wheelsthey are what you asked for, cheap, and strong.  I know a guy that runs them on the rear of his 227 mph record holding lakester at elmirage. he says the work great and cover the brakes
Offline JimL
I used the Centerlines with top-hat shaped hubs that moved the wheel inboard.  It was a simple lathe job that used my original bearings in the thick aluminum hub.  A local custom wheel manufacturer did them.
I dont know what it cost, it was a donation to the project.   It works with rear steering arms, but probably not with a tie rod in front.
