"250 CFM" computer fans are probably not going to do the lob. First, those fans' specs are probably pulled out of thin air (no pun intended) by marketing dweebs. Even if that rating was true, it is 250 CFM with zero back pressure-- not a realistic situation. Try to find some 12V industrial fans of similar size; they are much more likely to have the air-moving capacity that you need.
Regards, Neil Tucson, AZ
You are right. I asked a computer buddy today, who told me the same thing. They are not positive pressure fans.
Hotrod, Thanks for the vids. The guy in the video is even more out of the air than I am, but even with that twig on the bike it seems futile to draw air in.
To a streamliner guy, that looks like a lot of room. Just glass the tail up & turn it into an ice water tank with the radiators inside.
Seems pretty sparse to me, but I think this is my answer. I drew a quick mock up. I think I can only get about a gallon of water and ice in the reservoir. I will do some research, but any idea if that would be enough?
The only thing I can think of that might be a negative on the tail mounted water tank is an issue with weight and balance and center of gravity screwing up the bikes handling. Might want to run some tests with some weight up high back there to see if it will cause issues.
I have been running a water tank back there to spray the air cooled engine. The tank held water, battery, and pump. I never noticed the difference.
Thank you guys for the replies. Splaying the radiators, or using a scoop might do the trick, but I think getting any air there is ultimately going to be the downfall.
