Author Topic: #775 Returns to Bonneville 2013  (Read 7432 times)
Offline Frenchinjection
  • APS-BPS 750 Triumph Twin 775 . 152.35 record
    • Saltbike 775
« on: July 10, 2013, 10:11:22 AM »
Last year we did one run an trashed the supercharger.  This year we have done quite a bit to stop this and made the bike a bit more streamlined.
Re: #775 Returns to Bonneville 2013
« Reply #1 on: July 10, 2013, 10:15:35 AM »
How about a tail picture... that part is just as important as the great looking front... looks good.
See ya on the salt  8-)
    • Saltbike 775
« Reply #2 on: July 15, 2013, 12:38:07 PM »
Tail picture as requested.
« Reply #3 on: July 15, 2013, 12:41:40 PM »
A beautiful blue!
Offline fredvance
  • FVANCE
    • Vance and Forstall Racing
« Reply #4 on: July 15, 2013, 12:54:37 PM »
My favorite color!! :cheers:
Offline 38flattie
« Reply #5 on: July 15, 2013, 01:59:58 PM »
Looks fast! :cheers:
http://youtu.be/89rVb497_4c
Offline Ro Yale
« Reply #6 on: July 15, 2013, 11:03:24 PM »
Beautiful and the best of luck to ya!
Racers Race and Whiners Whine!
Offline Hellcat Customs
Re:
« Reply #7 on: July 16, 2013, 08:43:11 AM »
Beautiful... because I'm new, what motor are you using and what class
Offline Briz
    • Custom cycle developments
« Reply #8 on: July 16, 2013, 04:30:30 PM »
Very swoopy Steve! Best of luck over there.
    • Saltbike 775
« Reply #9 on: July 24, 2013, 08:48:25 AM »
For Hellcat and others.  The engine s basically a Triumph T120 with 750cc big bore, LF Harris cases, Billet twin plug head,  Billet crank, billet rods, MAP 10.5:1 pistons, Rotrex C30-94 supercharger, Ice water intercooler pump fed from a 5 gall tank.  Drinking methanol through Enderle constant flow injection.  Power is through an Air shifted GSX1100 gearbox modified for Belt primary drive with Sintered Iron slider clutch.  A Schnitz Pro2 Ignition sets fire to it and a RacePak V300 data logger tells us what went wrong. Front faring is based on KZ1200 pro stock bke mold modified for height & length. The front guard, front splitter and rear bodywork are all hand made.
There is not much Triumph left.
Offline peterdallan
« Reply #10 on: July 24, 2013, 09:58:33 AM »
Good luck Steve. From even that one run you could see it has all the attributes to go very fast indeed!
Peter
    • Saltbike 775
Update - #775 Returns to Bonneville 2014
« Reply #11 on: May 20, 2014, 02:26:47 AM »
I don't have much time for posting to the forums.  Last year we went 157 on the 140 record but did not impound it due to reliability issues.  We kept breaking belts and on one run split th block.  So this year we have a gear primary transmission made from KZ1000 gears and clutch basket spinning last years GSX1100 transmission.  The blocks have been machined from EN24T steel. Frame is now powder coat silver.  New Aeroquip Startlite fuel lines as they don't scratch your skin off when working on it.  Final build pic before it ships to the US.
« Reply #12 on: May 20, 2014, 02:42:00 AM »
That will break a record IMO. :cheers:
Go well and I wish you the best of British. Be safe.
Mike.
Offline SaltPeter
  • Can't you just be Serious for once in your Life!
« Reply #13 on: May 21, 2014, 03:31:44 AM »
 8-) 8-) 8-) 8-) 8-)
Pete  :cheers:
