Author Topic: C/Production Build.....  (Read 22638 times)
Re: C/Production Build.....
« Reply #30 on: November 06, 2013, 05:00:29 PM »
Wade, I Googled Cape Girardeau. Cool looking place. Very nice. :cheers:
« Reply #31 on: November 06, 2013, 05:33:16 PM »
Not sure how I missed this either.
Wade, I live in Festus, just up the road from you.  If there's anything I can do to help, please say the word.
I have a pretty nice machine shop at my disposal if you need to make any "custom" parts.
Did you ever get your torque arm problem figured out?
Offline Wade_Owens
« Reply #32 on: November 11, 2013, 11:08:22 AM »
Steve, we decided to leave the arm as long as possible and mount it off the side of the transmission, instead of on it. We'll use a large heim and weld to the arm. A removable ladder bar crossmember up from with up and down adjustment holes to compensate for ride height. Decided not to reinvent the wheel. This is an area I thought best left alone, for safety's sake.
Offline Wade_Owens
« Reply #33 on: June 24, 2014, 04:34:41 PM »
Just a quick update. I'll post some more pictures soon. We reinstalled the engine. Mounted the rest of the fuel system and lines. Mounted the ignition, battery and gauges. Mounted the radiator. A couple of upper strut rods to support the top of the seatback and it'll be good. Bought a powerglide cross member from UMR and modified it to fit the T-10. Zero'd the bellhousing and installed the flywheel and clutch assm. Also purchased 4 brand new wheels, tires and Moons at the Hot Rod reunion for $500. Pretty good deal. Used some panel bond to reattach the spoiler and put some securing screws in it.
I do need a little help. I'm told someone other than Mcleod makes a hydraulic throw out bearing. Does anyone know who that is? It needs to fit a Super T-10. I'm not opposed to the Mcleod, its just the price is not very inviting.
Thanks for help and stay tuned for the pics.
Wade
Offline Dynoroom
« Reply #34 on: June 24, 2014, 04:46:23 PM »
Quarter Master & Tilton also make hyd. release bearings but if McLeod $$$ got to you these will really knock you out.
Seriously Quarter Master makes an inexpensive unit that will work well for what you're doing.
Good Luck & Have Fun.
Offline redhotracing
« Reply #35 on: June 24, 2014, 07:17:08 PM »
We use a Howe Racing throwout bearing and have been very happy with it. Fairly inexpensive, as well.
Luke- Winston Salem, NC
Loring 2 Club- 201.252 (2010)
Ohio 2 Club- 203.712 (2013)
Offline jdincau
« Reply #36 on: June 24, 2014, 07:53:25 PM »
What hydraulic release bearing you need is determined by your clutch. The Howe unit would not work with our 10,000 RPM 2 disk mini clutch (not enough throw). We had to use this Coleman unit  http://www.colemanracing.com/Throw-Out-Bearing-Hydraulic-P4584.aspx which was suggested by the clutch manufacturer. Throw VS. master cyl bore dia. is critical and be sure to put in a pedal stop to prevent over centering the spring.
« Reply #37 on: June 24, 2014, 08:14:15 PM »
I see. How small is your clutch? We run a QM 3 disk 7.25" but the same bearing is good for a 5.5" as well.
Offline jdincau
« Reply #38 on: June 24, 2014, 09:39:20 PM »
 is not necessarily the diameter of the clutch but the dimension from the bell housing face to the release fingers and the throw required to release the clutch.
Offline Wade_Owens
« Reply #39 on: June 24, 2014, 10:17:13 PM »
Offline Wade_Owens
« Reply #40 on: June 24, 2014, 10:19:29 PM »
Offline Wade_Owens
« Reply #41 on: June 24, 2014, 10:22:03 PM »
Offline Wade_Owens
« Reply #42 on: June 24, 2014, 10:24:08 PM »
« Reply #43 on: June 24, 2014, 10:43:25 PM »
It looks good Wade. :cheers:
« Reply #44 on: June 24, 2014, 10:59:06 PM »
Great looking car!
