What type of project are you working on makr ? Where do you perform your testing, on a dyno or track ?Inquiring minds like to know. We hope to get some testing on the Iron Ghost at the Great Lakes Dragway "da Grove" in two weeks. Thursday eves. are Bikes & Slicks night - you can just about hot lap, and get tons of data to work with. Goin to freshin up the top end and change back to the E carb after Wilmington. LTA in July, then our favorite BUB at Bnvle in August. Life is good.We havin fun, or what Jimbo
That's cool. Did you take any pictures when you made it?
Very nice ! Thanks for posting the build pictures. In the video, that engine sure sounds happy.Jimbo
Earlier this year I was doing a lot of research on fuels for the Triumph. Some of the race fuel suppliers have gasoline that is specially blended for two strokes. Years ago I ran a 1974 Yamaha SC500 in the dez. It was a single cylinder air cooled two stroke. The piston was set up loose so it would not seize. Unfortunately, it would rock and rattle in the bore and a crack would form between the edge and a slot in the piston skirt. I had to put in a lot of new pistons as preventative maintenance. Water cooling like you have done would have been the solution.Nice job.
I just read all 11 pages of your build diary in 2strokeworld.com . You do amazing work. I'm looking forward to seeing the results, both on your dyno and the great white dyno. I wish you all the best after the supreme effort you've put forth. Pete
