Author Topic: Fire Systems  (Read 14417 times)
Offline Ron Gibson
Re: Fire Systems
« Reply #30 on: December 11, 2013, 04:49:33 PM »
SFI 17.1 Says systems can't be used more than 6 years, have to be de-commisioned after that time. Copyrighted, can't post rule.
Ron
Re: Fire Systems
« Reply #31 on: December 11, 2013, 04:54:50 PM »
BUT -- the SCTA Rule Book doesn't specify SFI certification.  Maybe Warner or Stainless will ring in on this.
Offline dw230
Re: Fire Systems
« Reply #32 on: December 11, 2013, 05:04:27 PM »
Sent question to Roy Creel.
Re: Fire Systems
« Reply #33 on: December 11, 2013, 06:14:44 PM »
He's at the Puerto Rico Independence (PRI) festival in, I believe, Indianapolis this year.
Re: Fire Systems
« Reply #34 on: December 11, 2013, 06:25:28 PM »
Hmm, I always thought PRI meant something else automotive related? Thanks for clearing that up Stan! :-D :wink: :roll: :cheers:
Offline Rick Byrnes
Re: Fire Systems
« Reply #35 on: December 11, 2013, 06:39:06 PM »
What is the expiration date of DRIVERS?
Rick
Re: Fire Systems
« Reply #36 on: December 11, 2013, 07:45:38 PM »
Comin' right up!
Re: Fire Systems
« Reply #37 on: December 11, 2013, 09:20:18 PM »
I can't guarrantee this definitively but I always thought ColdFire "corroded" Al bottles because it is a bipolar solvent, a "soap" Al2O3 is an impervious insoluable compound that protects the (very reactive)surface of pure Al, if you polish or  dissolve this very thin corrosion layer, another will form, and another......til it is all gone.
As for the argument about soap v Halon. I have clients with aquired brain injuries, one from being trapped in a space with limited oxygen, not long, but long enough. Choose your poison, for me its "soapy water" :cheers:
« Last Edit: December 11, 2013, 09:47:35 PM by Dr Goggles »
Offline TIIILSR
Re: Fire Systems
« Reply #38 on: December 12, 2013, 05:18:57 AM »
Thanks for the info guys, I am sure there will be more stated.
I am now in the market for a 10 pound push type FE-36 with 4 nozzles.
Jackpot motorsports
Re: Fire Systems
« Reply #39 on: December 12, 2013, 07:22:49 AM »
Good info thanks.
This year I have replaced a set of belts, a helmet and two fire bottles. I figure SFI knows more about safety than I do. But I can't say I enjoy replacing what appears to be perfectly good serviceable equipment.
As a side note for those building cars that want a certain look we can powder coat  a 5 or 10 lbs fire bottles any color you want. We then send the bottle to FireBottle and they will build and charge the system. We can even polish the bottles if you want that custom look.
