Why not just go with the wider front rim? You could mount a relatively skinny 17" radial tire. Like from a 125cc road racer.
I couldn't find an appropriately speed rated radial for the front. There's a soft-compound radial Bridgestone road-racing slick that only fits a minimum rim width of 2.15". That's all I could find.
We're planning on running the 3.5" this year and graduate to the 1.85" for 2014.
I did find this blurb on the Avon motorcycle tire website:
"TIRES: RADIAL VERSUS BIAS
While running a bias ply front tire and a radial rear tire can be acceptable in certain applications, you should never run radial front and bias rear as this can create an instability issue."
If that's the case, then we can run this 1.85" front rim this year coupled with a radial rear tire (medium compound road-race slick...)
