What do you guys think of putting a check valve in the system. Something like a 40 PSI check, where everything up to 40 PSI goes to the lifters, then after 40 psi, the check opens sending oil to the piston oilers? 40 psi is just a arbitrary point, right now.
I don't like this idea, and here are my thoughts on it -
Keep the oil flow constant everywhere. You want consistant heat removal, not one dependent on the whims of a check valve.
If you drop pressure temporarily, or the check gets clogged, an air bubble, you need to back off to get traction, or for what ever reason, the pistons will get way hot, and then -
SPLASH - you'll be quenching them when the pressure rebounds. That could be a huge heat differential on the bottom of the crown in a very short period of time.
And I also expect your pistons will be running a little warmer this year.
