Author Topic: Parachute tubes.  (Read 10469 times)
Re: Parachute tubes.
« Reply #15 on: September 18, 2013, 06:39:37 AM »
Thanks Speed Limit. Do you maybe have pics on the sysem for the liner?. It would help me big time. :-)
« Reply #16 on: September 18, 2013, 05:12:36 PM »
Here are a couple.  The tubes follow the frame, getting wider as it gets deeper.  I could take some other pics if you need them, there is a big dent currently in the top tube....
« Reply #17 on: September 19, 2013, 12:54:05 AM »
Thanks stainless. That really helps.
Offline Jon
« Reply #18 on: September 19, 2013, 06:39:36 AM »
My chute tubes taper slightly the other way smaller at the front than the back.
Partly to help get tyre clearance, partly thinking the deployment bag will come out easier.
Thanks for the pics Stainless, would I be able to get a pic of your chute retain/release mechanism on you pilots please?
Thanks
jon
Underhouse Engineering
« Reply #19 on: September 19, 2013, 09:24:43 AM »
Jon, the first picture shows that part.  The top tube was the manual release chute, spring pilot, the bungee was clipped in by the release cable. The other chutes were retained by the bungees you see, clipped over the posts. a single bungee held the chute and pilot. The pilots were pneumatically ejected, so when it fired, the bungee was popped off the retaining post and the chute deploys.
Let me know if you need a close up. The remains are in the trailer.  :|
Offline Jon
« Reply #20 on: September 19, 2013, 02:51:33 PM »
Thanks Stainless
Very glad your ok.
Thanks
jon
Offline Jack Gifford
« Reply #21 on: September 20, 2013, 01:56:39 AM »
My lakester (bought complete less engine) doesn't have a chute tube, and last ran legally (ECTA) in 2009. Have rules changed to now require a chute tube? (I only have a 2010 rulebook).
M/T Pontiac hemi guru
« Reply #22 on: September 20, 2013, 08:44:55 AM »
Jack, requirements based on speed of standing record.
chute required above 175 IIRC
« Reply #23 on: September 20, 2013, 09:36:20 AM »
If you are required to run a chute, you can use a tube, a traditional pack or hatch like Goggles and others have.
« Reply #24 on: September 21, 2013, 12:53:48 AM »
