Author Topic: Tires  (Read 3320 times)
Offline cafeswartz
Tires
« on: May 14, 2013, 11:04:29 PM »
Hi all, first time post and racer here. Trying to get it together for Maine. 64 Pontiac wagon needs tires for the street class and soon up to 150 mph. Can I get some brand names or current use tires that are V Rated in the 225/75r. X15 wheel size or your helpful suggestions. wheel width is 7".
Thanks all.
Offline saltwheels262
  • LTA 7/2013
Re: Tires
« Reply #1 on: May 15, 2013, 01:30:42 AM »
do they make Z rated tires in that size?
that may be better.
from show low.
ohio -    - 185.076 w/#684
lta 8/14  - 169.xxx. w/sw2
'16 -- 0 runs ; 0 events
                            - franey  8/2007
Offline 55chevr
Re: Tires
« Reply #2 on: May 15, 2013, 06:43:43 AM »
I suggest you contact Steve Van Blarcom ...
badcoupe34@sbcglobal.net
He is the LTA  Tech Director for Cars
Offline salt27
Re: Tires
« Reply #3 on: May 15, 2013, 09:16:03 AM »
Firestone makes or at least did make a V-rated Firehawk in a 225/70/15.
Offline bearingburner
Re: Tires
« Reply #4 on: May 16, 2013, 09:06:36 PM »
That Firestone tire I believe is no longer available. Last time I looked at their web site only a 16" tire is available.
Offline salt27
Re: Tires
« Reply #5 on: May 17, 2013, 12:51:41 AM »
It looks like you are correct.
I do have a well used set left.
Offline 55chevr
Re: Tires
« Reply #6 on: May 17, 2013, 06:33:21 PM »
well used ... ah, already shaved.
Offline cafeswartz
Re: Tires
« Reply #7 on: May 28, 2013, 01:11:51 PM »
I'm the OP and confused by the rule book(pg 12) on this matter. The cover page for Street class says tires must be rated for 135mph, however the rulebook lists tire speed ratings and the speeds the tires can run which are all higher than the speed rating per the tire manufacturers.
eg an H rated tire is a 130 mph tire according to published speed ratings by tire Mfg but LTA allows higher speeds?
Offline Gary Perkinson
Re: Tires
« Reply #8 on: May 28, 2013, 04:39:39 PM »
Thanks all.
Check www.tirerack.com. It's a great site that lets you search by everything, including speed rating. I bought a set of W-rated Kumhos (good to up to 168 mph) for the April event in Wilmington for about $85 apiece. That was obviously way more tire than I needed for the 115 mph I ended up running in my HHR, but hey, for $85, why not?
LTA   G/BGALT Record (1 mile)     143.313
LTA   G/BGALT Record (1.5 mile)  148.321
LTA   F/PRO Record (1 mile)         114.668
Re: Tires
« Reply #9 on: May 28, 2013, 06:15:18 PM »
It's a lot better to have a tire that's rated for a lot faster than you plan to run than one that's rated for less than you plan to run.
