Author Topic: Brunskilltown Bullet  (Read 100066 times)
Re: Brunskilltown Bullet
« Reply #90 on: July 20, 2015, 12:44:38 AM »
Ok, so we know we're talking the same language here, no pun intended Mate. :-D
Just so you know ahead of time, the tapered panel Deist's are probably going to spin. That shouldn't be a big deal to you on a rundown from 200 to 250 ish, on a 3 to 400 car they will close up without a spinner mount.
You have two low speed options in a 14 & an 18, my suggestion would be to start with the 14 & see how "you" like it. If you want more hit, go up to the 18.
With an 18' tow line & 15' shroud lines you have 33' to the canopy, that'll work. Now your high speed tow line needs to be longer than that  to prevent tangle.
The high speed you have sounds like an odd little critter, 30" to single shroud lines with a 12" center panel.
When you deploy a low speed on top of a high speed, the low speed will kill the air to the high speed & it will stop flying. It tends to beat the $hit out of the high speed getting dragged on the salt so if you don't need to use both, don't. You're only required to have more than one chute beyond 300 & even then you can run it down on one unless you need to get it stopped in a hurry.
Hope this all helps.
Offline DLRA#363
« Reply #91 on: October 02, 2015, 06:37:05 AM »
More progress with the car over the past few months with the rear end mounted with 2 optional positions to give 1" variation in ride height.
Offline DLRA#363
« Reply #92 on: October 02, 2015, 06:40:58 AM »
Fitted removable members to facilitate engine removal etc.
Offline DLRA#363
« Reply #93 on: October 02, 2015, 06:47:52 AM »
EGT Probe for each cylinder!
I was reminded by our tech people that the tall breathers on the engine would be an issue should we fall upside down and dump the engine oil onto the salt so a new breather system was machined up to take the vent line to the rear of the car and down below the camshaft center line.
Offline DLRA#363
« Reply #94 on: October 02, 2015, 07:01:12 AM »
The mill bed came in handy when setting up the new diff center gear set :-) :-)
« Reply #95 on: October 02, 2015, 09:33:35 AM »
 :cheers:  yep'ers
Offline DLRA#363
« Reply #96 on: October 03, 2015, 03:44:03 AM »
Fuel Cell compartment going together.
« Reply #97 on: October 03, 2015, 11:33:36 AM »
Is there a strap or something across the top to retain the cell? Nice build!
Offline DLRA#363
« Reply #98 on: October 03, 2015, 04:55:22 PM »
There will be 2 stainless straps securing the tank in place Neil.
« Reply #99 on: October 03, 2015, 10:01:18 PM »
:cheers:  yep'ers
I think that was Sparky's drooling noise over your sanitary fabrication! :-D
Offline DLRA#363
« Reply #100 on: October 05, 2015, 08:58:00 PM »
Thanks Sid, Some more shots of the fuel cell compartment.
I don't plan to fully enclose it but impede any engine fire from direct impact on the RCI fuel cell.
Front plate and base are .125" steel and the side plates from marine grade ally (the same thickness).
I will in addition to the required fire bottles have an extra 10lb auto activated unit with the head positioned just in front of the fuel cell area.
« Reply #101 on: October 05, 2015, 10:01:41 PM »
Looking good. :cheers:
Offline DLRA#363
« Reply #102 on: November 21, 2015, 05:08:11 AM »
Cooling circuit now sorted.
Offline DLRA#363
« Reply #103 on: November 21, 2015, 05:12:16 AM »
Fire bottles installed with an additional 10 Lb auto bottle for the engine area.
« Reply #104 on: November 21, 2015, 06:53:09 AM »
For some reason these latest pictures didn't come through even though all you've posted in the past have been just fine. All I see are those little red x's. Is it possible they were too large?  :? :? :?
« Last Edit: November 21, 2015, 06:55:00 AM by Peter Jack »
