Author Topic: Brunskilltown Bullet  (Read 100004 times)
Offline BHR301
Re: Brunskilltown Bullet
« Reply #105 on: November 21, 2015, 08:00:30 AM »
Peter Jack...They show up on my computer.
« Reply #106 on: November 21, 2015, 08:25:35 AM »
They show up on mine now too!!!!  :cheers: :cheers: :cheers: :cheers:
This project just continues to look nicer and nicer. Well done!!!
« Last Edit: November 21, 2015, 08:28:33 AM by Peter Jack »
« Reply #107 on: November 21, 2015, 04:28:48 PM »
It;s looking good Cookey
Offline DLRA#363
« Reply #108 on: January 03, 2016, 07:03:06 AM »
Happy New Year to my fellow Land Speed Racers.
Been keeping at it with the target date for our DLRA 2016 Speed Week event getting very close now.
The buck has been made up for the nose of the car and will be initially molded in glass fiber then probably carbon composite.
Offline DLRA#363
« Reply #109 on: January 03, 2016, 07:08:40 AM »
With the bottom of the car being flat an alloy plate support section has been fabricated to bolt onto the main chassis.
The nose section will be fixed to this with Dzus fasteners.
Offline DLRA#363
« Reply #110 on: January 03, 2016, 07:15:48 AM »
Primary chute release will be actuated with a button on the steering wheel with the mandatory manual back up.
Using a boot popper solenoid to do the job :cheers:
« Reply #111 on: January 03, 2016, 07:37:53 AM »
Awesome update and the quality is top notch.
I hope 2016 brings you much success. The car is unbelievable. :cheers: :cheers: :cheers: :cheers: :cheers:
Offline DLRA#363
« Reply #112 on: January 03, 2016, 07:53:51 AM »
Using some Innovate Motorsports gear to log the run data for the car and also stuff from Spud Miller at Fuel Injection Enterprises to enable control of the engine revs etc.
Therefore we need to add a crank trigger set up (to a 60 year old engine!!!) to do this.
« Reply #113 on: January 03, 2016, 04:25:57 PM »
Looks like your body shape plan is for a flat bottom car, was that your intent when you did your first design? I ask because you made a lot of effort to make the bottom of the chassis round.
Really great work,can't wait to see the finished car!!!
Offline DLRA#363
« Reply #114 on: January 04, 2016, 07:15:22 PM »
Hi Rex,
Your'e right the rounded bottom of the car was my original concept and a lot or work went into it to follow along the Belly Tank theme.
Reading about and looking at other salt and high speed circuit racers I changed my mind and figure 'Oh well weight is our friend' so a few pounds extra wont hurt! :roll: :roll: :roll:
Offline DLRA#363
« Reply #115 on: January 25, 2016, 02:51:18 AM »
Well we are now down to the final welding of the main chassis with a few body mounting tabs etc to go on.
About 5 weeks to go before the car's debut at our DLRA 2016 Speedweek.
Have run the engine on alcohol and am pleased with our initial set up.
All has now been dismantled and I am happy with being able to do this without extra assistance.
Once the chassis has the main welding done I will add the necessary Dzus Fastener tabs as required and then shoot some etch primer onto it.
Offline DLRA#363
« Reply #116 on: January 25, 2016, 02:54:00 AM »
« Reply #117 on: January 25, 2016, 03:10:48 AM »
Fantastic. :cheers:
I'm happy for you and I can't wait to see the Bullet on rubber.
Go you good thing. :cheers: :cheers: :cheers: :cheers: :cheers:
Offline Polyhead
« Reply #118 on: January 25, 2016, 07:41:43 AM »
Wow, early hemi and a torqueflite.  You'll have to let me know how the torqueflite does.  I'm going to be running one in my project with a Polyspherical.  I've been concerned with it sucking up too much power.
Ben 'Polyhead' Smith
  KE7GAL
« Reply #119 on: January 25, 2016, 08:52:28 AM »
Ben, you must be excited now!!!!. :cheers:
