Author Topic: APS/Ω Gas turbine bike build  (Read 930976 times)
« Reply #1245 on: February 20, 2016, 04:55:15 PM »
Go Fast, be safe. Really pulling for you and a record. :cheers:
Offline Mobacken Racing
  • Turbine junkie
    • Mobacken Racing
« Reply #1246 on: February 21, 2016, 01:03:48 AM »
The jet kick hasn´t got what it takes for a shot at the jet class record, our friends with the pulsejet sled is close to breaking the 200km/h barrier and we can hope for a 150+ run if everything lines up. The unofficial jet kick record is set by another team that bought a gas turbine from a marine boat generator and converted it to thrust, they ran 170-something km/h a couple of years ago before crashing.
Our biggest enemy is, as always in this business, drag. For next year we need to make some sort of fairing for the kick if we want to go faster, it would be really fun to beat the jet kick record and with a slick fairing and 120kg of thrust we should be able to do it. :-)
  • Turbine junkie
    • Mobacken Racing
« Reply #1247 on: February 23, 2016, 01:24:11 PM »
Only two days until Speed Weekend and the jet kick is ready to go, so I spent last night in the workshop on the JU-02 engine.
I made the shaft tunnel casting deliberately long until I knew the exact measurements of the engine, after assembling the axial bearing and fitting the turbine shaft I could measure how much I needed to remove. On the pic I have also started to make an alignment ring so I won´t have to use dowels.
With that done I made a stainless seat for the turbine shaft piston ring seal, I will weld it to the rear NGV wall later.
Arboring the hole for the ring seat.
Here the seat is pushed in place, I have some work left to do on the NGV wall before I can weld it.
The turbine shaft fitted in the seat to test the fit.
I reached some kind of mile stone 23:30 last night when I could assemble the diffusor plate and shaft tunnel with the rotor in place!
Cheers!
/Anders
Offline saltwheels262
  • LTA 7/2013
« Reply #1248 on: February 23, 2016, 05:14:24 PM »
That the future played, rotor and shaft tunnel is a piece of art.
Good luck this weekend and ride safe.
Bf262
ohio -    - 185.076 w/#684
lta 8/14  - 169.xxx. w/sw2
'16 -- 0 runs ; 0 events
                            - franey  8/2007
Offline Old Scrambler
  • Going Fast - Slowly
« Reply #1249 on: February 23, 2016, 05:43:09 PM »
Vertualy HAND-MADE.........marvelous, simply marvelous :-)
  • LTA 7/2013
« Reply #1250 on: February 23, 2016, 06:19:29 PM »
Bf262
I usually proofread.
~~ it should have read the diffuser plate, rotor and shaft tunnel ~~
       That will happen with voice commands.
                            - franey  8/2007
Offline salt27
« Reply #1251 on: February 23, 2016, 06:45:18 PM »
Bf262
I like the first post, it sounded prophetic.   :-D
  • Turbine junkie
    • Mobacken Racing
« Reply #1252 on: February 24, 2016, 03:03:16 AM »
Bf262
I was a bit curious about what you meant, now I get it.  :-D
Thanks guys, I try my best to make the build interesting to follow despite the numerous closeup pics of engine parts unknown to any other than the builder himself. :-)
Cheers!
/Anders
Offline bbarn
« Reply #1253 on: February 24, 2016, 10:23:48 AM »
I don't know about the rest of the crew here but when I see a post in your build thread I get excited!!!!
It's a good day when you post updates Anders!
  • Turbine junkie
    • Mobacken Racing
« Reply #1254 on: March 01, 2016, 04:51:30 PM »
That is good to hear!  :-)
I just got home from Speed Weekend on Ice here in Sweden, I´ve posted some info in the landracing.se subforum but here is the friday movie where we ran 139.2km/h with the jet kick sled.
https://youtu.be/-saNDl5U8ZE
Not bad at all for a home built sled standing on the runners 2cm from the ground, but if it weren´t for oil pressure problems we could have gone much faster on Saturday when we increased both turbine revs and afterburner fuel rate dramatically. 8-)
Cheers!
/Anders
« Reply #1255 on: March 02, 2016, 08:23:32 AM »
Rocket man!!!!!. That must be a wild ride. :-D :cheers: :cheers: :cheers:
Offline Buickguy3
« Reply #1256 on: March 02, 2016, 09:16:21 AM »
  If his feet slip, it'll be fried cajones.
                   [America]
  • Turbine junkie
    • Mobacken Racing
« Reply #1257 on: March 05, 2016, 01:28:57 AM »
Actually it is a quite pleasant ride according to him, at least compared to the earlier jet kick we built that didn´t have a suspended engine cradle. That one was a wild ride, luckily it didn´t go much faster than 100km/h......
  • Turbine junkie
    • Mobacken Racing
« Reply #1258 on: March 12, 2016, 08:44:18 AM »
I´ve been up to my neck in work since Speed Weekend but I managed to find a couple of minutes to reroute the oil tank vent line into some sort of ejector in the exhaust pipe, the idea is that this will maintain a slight under pressure in the tank to assist in scavenging oil from the engine and gear box.
Cheers!
/Anders
  • Turbine junkie
    • Mobacken Racing
« Reply #1259 on: March 21, 2016, 07:06:08 PM »
Thanks to a hint from PorkPie I have reconsidered the ejector style oil tank vent, the risk of setting the oil smoke on fire and on top of that risk pulling oil up through the hose with the under pressure created I decided to make a separate ventilation instead. I spent a couple of hours in the workshop building a catch tank for the oil tank vent tonight.
Since my foot will be on the footpeg there isn´t room for a larger volume catch tank but I think this will do, a nice big breather filter on top will let any air trapped in the oil tank out quickly.
As soon as the weather improves and I find a couple of hours of spare time I will roll the bike out for a test start!
Cheers!
/Anders
