Author Topic: APS/Ω Gas turbine bike build  (Read 938119 times)
Offline Mobacken Racing
  • Turbine junkie
    • Mobacken Racing
« Reply #1005 on: June 28, 2015, 01:30:20 AM »
Is that steering damper from a 2012+ S1000rr?   The 2009-2011 dampers are kinda weak, non-adjustable.  I replaced mine with a 2012 and it was a difference between daylight and dark.
This one must be newer since it has an adjustable knob at the end of the damper rod.
Offline RansomT
« Reply #1006 on: June 28, 2015, 11:50:27 AM »
Good, you will be happy then!   Just what you needed...
  • Turbine junkie
    • Mobacken Racing
« Reply #1007 on: June 28, 2015, 04:44:53 PM »
There is a slight noise from the steering damper just like there is some air trapped inside it when pushing the front end hard from side to side, is that normal?
Offline RansomT
« Reply #1008 on: June 28, 2015, 08:26:38 PM »
I don't remember that being case, however I can check it out when I get my BMW back.  I don't have my bike here right now, it's at the BMW shop for a fuel pump recall.  Should be ready next week.
A lot of road racers like replacing those stock pieces with high end ones, but the newer BMW pieces seem to work very well and are reliable.  I wouldn't suspect your damper being bad, not yet anyway.
  • Turbine junkie
    • Mobacken Racing
« Reply #1009 on: June 29, 2015, 03:30:29 AM »
Thanks, it is probably not a big deal since the function seems ok despite the noice.
My previous china damper piston had a slack of several millimeters when changing direction so it was practically useless, this one is very tight and smooth so I hope that the steering instability after hitting a bump at speed is gone now.
  • Turbine junkie
    • Mobacken Racing
« Reply #1010 on: June 30, 2015, 05:12:46 PM »
I weighed the bike yesterday, 186kg dry isn´t bad at all considering the heavy cast iron gearbox and the car battery. :-)
I also spent a lunch break grinding and polishing the steering damper mount a bit, now it looks more presentable.
Cheers!
/Anders
  • Turbine junkie
    • Mobacken Racing
« Reply #1011 on: July 31, 2015, 02:18:08 PM »
While waiting for the One Mile race in September I sent the rotary assembly for the upgraded engine I am about to build away for 3D-scanning.
This way I can get the wing profile directly in the CAD program and 3D-print a casting mold without having to find the radius by trial and error as I did with the engine I use now.
I got an email today with the scanning pics, the scans are done and post processing is under way.
Cheers!
/Anders :-)
  • Turbine junkie
    • Mobacken Racing
« Reply #1012 on: August 31, 2015, 01:22:32 PM »
Adjusting the idle before the One Mile race in Färila, Sweden this weekend.
https://youtu.be/io0qcR0HATU
« Reply #1013 on: August 31, 2015, 02:13:38 PM »
"Oh well, that's normal, too."   :cheers:
« Reply #1014 on: August 31, 2015, 02:19:18 PM »
I always enjoy your posts Anders. Your laid back attitude is a great example for others (me???).  :cheers: :cheers: :cheers:
« Reply #1015 on: August 31, 2015, 02:30:20 PM »
Good luck Anders, looking forward to your report after the event.  :cheers:  Dean
« Reply #1016 on: August 31, 2015, 02:56:32 PM »
I'd worry about getting "hot roasted nuts" without the ice spray coming back.
  • Turbine junkie
    • Mobacken Racing
« Reply #1017 on: August 31, 2015, 03:10:31 PM »
4-barrel Mike: "Normal" is everything that doesen´t cause an immediate and total engine failure. :-)
Peter Jack: Thank you, I might sound relaxed but my heart is often pounding like a rabbits during hunting season when I test my engines... :-D
sabat: Thank you! I´ll make sure to get lots of video footage and I´ll stay off the saturday beer so I remember what to write in the race report.
Stan Back: The seat gets rather hot but I think I´ll be fine. I have a heat shield that keeps most of the radiant heat from the exhaust away from me.
Cheers!
/Anders
Offline Speed Limit 1000
« Reply #1018 on: August 31, 2015, 07:19:10 PM »
Very impressive :cheers: Hope you go fast :-D
  • Turbine junkie
    • Mobacken Racing
« Reply #1019 on: September 01, 2015, 04:28:05 AM »
Thanks, I hope so too! :-)
