I just got back from the fab shop. We installed the seat and I climbed in. My shoulder is completely inside the inside plane of the cage, much less the outside. BUT, part of the supporting structure of the seat (Kirkey full containment) around the shoulders goes a bit beyond the outer plane (is that a problem). The inside of the seat is inside or at the inner plane, but the outside of the square tube that's wrapped around the shoulders on that seat is outside the outer plane. If the rule is 'my SHOULDERS must be inside the outer plane' then I should be fine. That said, we're adding another bar to move that 'outer plane' further out, so that the outer edge of the seat is inside the outer plane too. It'll run horizontally from the vertical bar to the left of my head, with a kink it in going back around to the main hoop. As close as it can be run to the door. We both really liked the addition...
Additionally, we're going a bit gusset crazy at this point. It's not hard to add them now, to better to have more than is needed than to come up short in any way.
Thanks for the comment on the window net, that was actually my 'homework' for today. I've got to go dig that section up in the rulebook as we'll be adding that soon, and the reminder to keep the release inside the outer plane is helpful!
