Sometimes I'm a little dense, and this is one of them. I haven't competed at SCTA events yet, but this new addition to the 2013 rules has me baffled:
7.D CLASSIFICATION of DISPLACEMENTS, FRAMES, ENGINES, and ENGINE TYPES:
7.D.3 Engine Displacement Classes:
Displacement shall be greater than the maximum allowable for the next lower class. To permit minor reconditioning of worn cylinder blocks in classes other than Production, it is permitted to increase cylinder bore diameter .020 in. (.508 mm) beyond that which provides maximum displacement for the class only if the OEM bore diameter is within .020 in. (.508 mm) of the maximum class displacement.
If the OEM bore diameter is within .020" of the maximum class displacement, then boring by .020" isn't going to increase the displacement beyond the maximum class limit, unless one has already increased the stroke to the limit. Am I missing something? And does this mean I can't bore my motor beyond .020" in classes other than production?
Edit! I think I got it! If the OEM bore is within .020" (less than), then an overbore of .020" would make it over the limit, and now this is permitted. I.E., my B50 (my roadracer) is 498cc from the factory (84mm x 90mm), but I've bored it .5mm (.020"), and now it is 504.5cc. This is now legal by the new rules to run in the 500cc class. Is this right?
