Author Topic: Aerodynamic battery cut off activation.  (Read 22295 times)
Re: Aerodynamic battery cut off activation.
« Reply #15 on: February 21, 2013, 02:25:35 PM »
Rob,
How about welding a tab down off a hartwell latch.
I was thinking of this at my desk, I am going to play with the idea when I get home tonight.
Offline Joe Timney
    • Delaware Chassis Works
« Reply #16 on: February 21, 2013, 05:34:38 PM »
To make it a pull, just run the cables the other way!
Joe Timney
Retired President of ECTA
www.delawarechassisworks.com
Offline Plmkrze
  • Oh Yea
« Reply #17 on: February 22, 2013, 02:42:47 PM »
Mount the pull/push handle in a recessed space similar to a NACA duct.
"Trim it, whittle it, make it work."
East Coast Cherry Pickers Association (ECCPA) and proud of it!
Offline robfrey
    • carbinitelsr
« Reply #18 on: February 23, 2013, 10:17:31 AM »
Too turbulent. Think smoother.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
Offline robfrey
    • carbinitelsr
« Reply #19 on: February 23, 2013, 10:29:55 AM »
Rob,
Tman, did you come up with anything?
I was thinking of fabbing a 1.5 wide x 8" long flat rocker rocker switch that would sit flush when switch is in the on position. Maybe I can make the handle part itself extra thick (maybe 3/8" aluminum) so that it can stick up above the body work a bit then be contoured to match the body within a few thou using a flap wheel.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
Offline maguromic
« Reply #20 on: February 23, 2013, 10:31:31 AM »
On our roadster build we are going to use a solid state battery isolator and use a flush mounted push button.  Tony
Offline JoshH
« Reply #21 on: February 23, 2013, 10:37:01 AM »
Tony, which one?
« Reply #22 on: February 23, 2013, 01:48:27 PM »
Why not make the rotary switch lever out of aluminum that is formed into a thin airfoil. It would be at right angles to the body but in the "ON" position it would be parallel to the airflow so its drag would be almost nil. The "OFF" position would be high drag but who cares?
Offline robfrey
    • carbinitelsr
« Reply #23 on: February 23, 2013, 02:09:46 PM »
The problem with this idea is a problem of position. Due to real estate reasons the battery needed to be in the front of the car. Switch should not be positioned in front of the widest part of the car as it will disturb laminar flow. We did not want to run wires all to the back of the car then all the way back up to the front to all the electronics. It is safest if the switch is as close to the battery as possible.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
« Reply #24 on: February 23, 2013, 02:34:38 PM »
A  small thin airfoil should not disturb the airflowat all....?
Offline jdeleon
    • DELEON AUTO ACCESSORIES
« Reply #25 on: February 23, 2013, 03:14:18 PM »
Rob,
http://www.hartwellcorp.com/pdfs/Hartwell%20Corporation%20Brochure.pdf
page 4-6
Should give you a pretty good idea of what I was thinking.
Offline robfrey
    • carbinitelsr
« Reply #26 on: February 23, 2013, 07:12:11 PM »
Bugs disturb airflow.
Any protrusions at all off the fuselage will create a wake on a high laminar flow body making the whole shape a bit less efficient.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
Offline robfrey
    • carbinitelsr
« Reply #27 on: February 23, 2013, 07:19:13 PM »
Javier.  Could I also use this to reset the switch or would this be a one way only thing?
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
Offline maguromic
« Reply #28 on: February 23, 2013, 08:05:04 PM »
Tony, which one?
I have the one made by CRATEK http://motorsportcables.com/content/battery-isolation  , but there are plenty of companies that make inexpensive units. Tony
« Reply #29 on: February 23, 2013, 08:11:59 PM »
Bugs are not airfoils,  ... at least the bugs that I've seen.  :-D
