Author Topic: Aerodynamic battery cut off activation.  (Read 22278 times)
Offline robfrey
    • carbinitelsr
« on: February 20, 2013, 12:20:48 AM »
Looking for a nice clean way to activate our cut off switch for our # 496 liner. Any ideas?
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
Offline Joe Timney
    • Delaware Chassis Works
Re: Aerodynamic battery cut off activation.
« Reply #1 on: February 20, 2013, 07:47:50 AM »
Flaming river remote unit, it has a rod that activates it. A quality part! I have had a cheap kill switch short out and blow a hole in the metal housing.
Joe Timney
Retired President of ECTA
www.delawarechassisworks.com
« Reply #2 on: February 20, 2013, 10:11:16 AM »
Rob, ours is on the push bar, cable operated to the front of the car where the battery and switch are.
« Reply #3 on: February 20, 2013, 10:42:28 AM »
The 444 Vesco liner has a push rod in the nose and a cable pull to the driver, a single lever is all that's required.
« Reply #4 on: February 20, 2013, 11:17:23 AM »
Isn't that kinda rude calling the safety guy a jerkoff? :-D
Offline Plmkrze
  • Oh Yea
« Reply #5 on: February 20, 2013, 12:06:05 PM »
not to mention it may be painful! :-o
"Trim it, whittle it, make it work."
East Coast Cherry Pickers Association (ECCPA) and proud of it!
Offline robfrey
    • carbinitelsr
« Reply #6 on: February 20, 2013, 04:45:42 PM »
I like that. I figured we would do it cable actuated to a flaming river switch which should be here today but was not quite sure how the actuator would work.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
Offline robfrey
    • carbinitelsr
« Reply #7 on: February 20, 2013, 04:52:28 PM »
Oh yeah! No cheap switches here. I once watched a guy chase electrical gremlins for an entire season never making a good pass. Problem eventually traced to old cheap corroded cutoff switch which kept braking contact. I bet that cheap switched cost him thousands not mentioning the embarrassment of not making a good pass for about a year! That cheap switch was quite expensive!
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
« Reply #8 on: February 20, 2013, 07:59:02 PM »
How many times do you hear of problems created by parts like that. We always look for the big thing that went wrong. It happens to all of us at some stage.
Offline Joe Timney
« Reply #9 on: February 20, 2013, 08:04:53 PM »
Switch setup with custom arm and dual cables. One out the back, with the other for the driver. I mount the switch next to the battery.
Hope it helps.
Joe Timney
Offline robfrey
    • carbinitelsr
« Reply #10 on: February 21, 2013, 09:11:16 AM »
Thank Joe. I do plan to use cable system but I don't want to drag a handle like that through the air. I looking for a clean actuator that can be recessed into the bodywork or something.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
Offline Joe Timney
« Reply #11 on: February 21, 2013, 10:25:53 AM »
Just add an aluminum post to the cable end. I buy my cables from www.surplusunlimited.com in Daytone Beach, a couple of blocks toward the ocean from the 500 Track. The 33C are the red Morse cables... less than the race supply houses.
Joe Timney
Offline JoshH
« Reply #13 on: February 21, 2013, 11:23:35 AM »
Rob, that cable system looks good. Couldn't you configure it to be a pull instead of push?, then you could countersink the handle with enough space around it for a good finger grip. A few tenths lost speed wise is worth the safety aspect. I'm going to use Joe's setup for sure. Thanks Joe, great system.
Offline jdeleon
    • DELEON AUTO ACCESSORIES
« Reply #14 on: February 21, 2013, 02:10:35 PM »
Rob,
How about welding a tab down off a hartwell latch.
