Ok, guys, we are going to treat this strictly as streamlining, and leave the scoop battle for someone else.We will modify the scoop buy cutting it approximately like the pic.
The official say:
The rules committee agrees that at this time, if you remove the tail section of your scoop that is climbing up the windshield to the top of the car past the vertical plane of the cowl, we will back you up that it complies with the rules. Add this email to your log book files...
Dan, I know all of know you have personal lives and these things take up a lot of your time. Once again, many thanks!
Dang.. can't these committee members read the rule book
? Or are they talking about the very top by the trailing edge of the windshield? Seems they should allow whats in the rule book. Again the ''cowl'' definition. Are they saying the firewall is the end or start of the cowl?
''No part of a foward facing hood scoop can extend foward of the leading edge of the hood,be more than 11''
above the surface of the hood at the centerline or extend past the trailing edge of the hood more than 11''.
Clearance between the scoop and the windshield must be a minimum of 1/2''.''
DOES it say it can extend 11' past the trailing edge of the hood with a minimum clearance of 1/2'' or NOT.
Don't cut anything untill you get an explaination of this in writing.
