John, you're correct. However, I don't find 'cowl' defined in the rules, so where it ends is open to interpretation.
John and I discussed this prior to John fabbing it up. There are several record setting cars that ran similar configurations, with no issue. The rules on this have changed very little, even with the 2013 wording.
The rule for scoops is a poorly written rule, as it does not address hood scoops for blown cars. It appears that the rule assumes scoops are ONLY ran on 'un-blown vehicles'.
I'm going to submit a change to the rule, or at least the wording, next year. I must/might be the only one that has an issue with it, but it could sure be less ambiguous than it is.
The comp Coupe class is designed to be the fastest door-slammer class, so why would blown vehicles be hampered with rules written for un-blown cars?
If anyone has any suggestions on the wording/change, post them up or PM me.
