Author Topic: My salt addiction  (Read 341586 times)
Re: My salt addiction
« Reply #75 on: February 06, 2013, 03:50:00 PM »
Actually for road racing and oval track set up we don't necessarily use ackerman. The other name for ackerman is toe out in turns and it works well to prevent scrub when turning sharply. As speeds increase and tire loadings change the need often decreases and other alternatives often work better. Ackerman is probably the least worrisome item on the list of things to check for in front end geometry unless it's totally out to lunch and then there will probably some things that are even worse problems.
« Reply #76 on: February 06, 2013, 03:54:43 PM »
Ackerman huh? I guess that's a new one for me. What exactly does that mean?
Believe it or not the scrub is close. It was WAY worse with the other spindles that I had.
Yes, look up a diagram for Ackerman and it is easily understood.
« Reply #77 on: February 06, 2013, 04:12:33 PM »
Trent, PM sent.
Offline lsrjunkie
« Reply #78 on: February 07, 2013, 09:33:41 AM »
I appreciate the insight guys! Thank you!  :cheers:
Offline lsrjunkie
« Reply #79 on: February 08, 2013, 10:15:24 PM »
Well, after a quick lesson in steering geometery and a little redesign on my part, and a little more work... I have steering!  :-D Now if I only had a steering wheel to turn the whole mess!  :roll: I guess any progress is good progress.
Special thanks to Stan Back for the lesson!  :cheers:
Offline lsrjunkie
« Reply #80 on: February 08, 2013, 10:20:08 PM »
And for the record, I appreciate all you "old salts" for pointing me in the right direction and keeping me from killing myself out there! Or worse yet crashing my car!
 :cheers:  :cheers:  :cheers:
Offline Speed Limit 1000
« Reply #81 on: February 08, 2013, 11:53:00 PM »
I hope you understand some of us "old salts" only do it because if you crash, no one can run till they clean up the mess :roll: :cheers:
Offline DND
« Reply #82 on: February 09, 2013, 08:45:18 PM »
Hi LRS
In my early days of racing [ 50's - 60's ] you would see a car with the wheels getting into a shimmy, i was told that it was becaure the link between the box and the spindle was on a sharp angle like what you have.
Maybe some one here on the forum can sheed more light on this subject, wether it is a ' Old wives tale ' or it is something to look at?
Offline RidgeRunner
« Reply #83 on: February 09, 2013, 11:10:49 PM »
     Something that should be looked at.  If the forward end of the drag link where it attaches to the steering arm on the spindle is moving in a substantially different arc than the axle during suspension compression and rebound it can lead to bump steer and handling problems.
     A co worker was having handling problems on rough roads with his mid '50's F-100, power steering box from another make to clear the SBF headers.  Juggled the steering components around to better match the arcs and his handling issues went away.
« Reply #84 on: February 10, 2013, 01:07:10 PM »
I saw that, too.  No bump steer -- no axle movement.  Fixed to frame.
« Reply #85 on: February 10, 2013, 01:09:35 PM »
. . . tho if it were mine -- I'd shorten the pitman arm to slow the steering down -- and make it more parallel to the ground and look more "normal", too.
« Reply #86 on: February 10, 2013, 02:53:53 PM »
Some of us are not that old, I only have 10 years on ya! :cheers:
Offline Jon
« Reply #87 on: February 10, 2013, 03:05:59 PM »
"IF"...... your messing with the geometry again I would try to get the pitman arm to drag link at 90 degrees so the left and right turn arc are the same.
cheers
jon
Underhouse Engineering
Offline robfrey
    • carbinitelsr
« Reply #88 on: February 10, 2013, 03:52:26 PM »
cheers
jon
Good point Jon.
Keep it up LSR junkie! Your progress is amazing!
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
Offline Skip Pipes
  • I hate being bipolar, its awesome!
« Reply #89 on: February 10, 2013, 04:23:30 PM »
If you want to slow the steering down try a Howe quickener, installed backwards. A tip from JD. I installed this in my car.
http://www.landracing.com/forum/index.php/topic,6794.0.html
Skip's Garage
