Author Topic: What is the outright P-P World Land Speed record  (Read 13226 times)
Online Seldom Seen Slim
Re: What is the outright P-P World Land Speed record
« Reply #30 on: January 07, 2014, 01:11:29 PM »
Measuring off the bridge, the two guys say "The water sure is cold" and the other guy responds "Yeah, and it's deep, too". :?
Offline fredvance
  • FVANCE
    • Vance and Forstall Racing
« Reply #31 on: January 07, 2014, 01:13:17 PM »
snuck by me also!! :-P
Offline rouse
  • Impound is the place to be
« Reply #32 on: January 07, 2014, 03:03:50 PM »
That's why most my friends think I way to Nerdy :-D
They also accuse me of being Anal when I over analyze a project. :x
I think those limits on P and or PP engines makes it real expensive to make HP.
By the way, Thanks for fixing my urinal comment. I'll watch out for that language thing.
Rouse
Johnnie Rouse
« Reply #33 on: January 07, 2014, 07:46:57 PM »
good to see someone found it... I didn't find it.... thanks for the due diligence on that.  You guys on the other side of the world have skills....
Offline SaltPeter
  • Can't you just be Serious for once in your Life!
« Reply #34 on: January 09, 2014, 06:31:51 PM »
I am confused again ... So that's another difference between BUB and SCTA/DLRA, mmm..... :-D
2013 BUB/AMA Sup Regs:
CHAPTER 12:
ENGINE BY CLASSIFICATION
All classes are to use motorcycle engines. A motorcycle engine is defined as any motor that was specifically designed for use in a motorcycle.
12. A. PRODUCTION (P)
Use the same engines (gasoline only) originally installed in the specific motorcycle frame at the time of production and ensure it meets the definition set in the ā€˜Pā€™ frame class (See Chapter 4). Original equipment (OEM) shall include cylinders, cases (crankcases), heads, and carburation or throttle body (stock venturi size), kick-starter or electric starter. Displacement determines the class.
OEM displacement specifications must remain stock.
GASOLINE ONLY. Fuel not permitted in this class. See Chapter 2, paragraph 2.F.
P engine class shall not run in M, MPS, A, APS or S frame classes.
DLRA 2014 Rules (Based on 2013 SCTA)
7.J ENGINE CLASSES
7.J.1 Production:
Production engines shall be the same model as the model of the frame being used and shall have
STOCK EXTERNAL APPEARANCE. Production motorcycles shall use OEM cylinders, heads and
crankcases to comply with this class. OEM engine displacement determines the displacement class for competition.
Displacement may not be increased beyond that class limit.
Starting mechanism shall be retained and operable. Carburetors or throttle bodies shall be OEM for that model production engine.
All production engines run in gas class. See Section 7.D.3
I got caught short with Production Rules (SCTA Based) at my first trip to DLRA Speedweek in 2010, I did not know that the allowable Exhaust Mod Rule had changed to No Mods (and then it changed back again in later years). I changed Class and ran M/G instead. So I am a bit obsessive about Rule interpretation.. :-D
So the way I read it in Prod....BUB/AMA must remain OEM capacity and SCTA/DLRA you can go out to Class capacity.
Back to my Shed.
Pete the Nerd  :cheers:
