"I was told the 'microprocessor made it a computer."
If that's the case, use a Crane HI-6 CD ignition box. If I remember correctly, it is an analog unit-- no microprocessor.
Regards, Neil Tucson, AZ
Odd that I was just reading up on the Crane HI-6 and the user feedback vs. the 6AL is that it's "Digital" Now that doesn't nessicarly mean it has a microprocessor but it probably does, I've not dug into it that much. Also there is more than 1 MSD 6AL, the classic analog 6AL and the new 6AL-2 that I'm pretty sure the above quote came from.
I've still not received my rulebook so I was trying to hold off on adding anything to this thread till I had it in hand and have read it, but since it's moving I'll join in. Now if I'm not allowed to run anything that controls the engine that has a microprocessor other than a stock Buick unit this focuses my thoughts a bit more.
The next question along those lines is can I run any Buick ESC system from 78-81 or does it have to be an 81 to match my 81 body? Major differences is 81 has an ECM that was liked to the feedback carb, transmission lockup and such. From a timing perspective as best I can tell it merely pulls 10deg of timing if the knock sensor goes off. This is the same function provided by the earlier units that didn't talk to the carb, O2 sensor or really anything else other than I think CLT so it knew if the engine was warm enough to have cleared up all the cold clearance rattling.
In case it's really aimed at the programable aspect, can I run a microprocessor containing but non-programable ignition system that to get to work you set the timing and turn a knob on a potentiometer to set you retard/boost ratio?
Finally can I run both the stock Buick ESC system and an analog (or digital, non-programable) ignition system in tandem? MSD has wiring diagrams on how to run thier 6BTM with the ESC system so it looks like it's possible.
I've just convinced the wife that this project is a go so I'm seriously working on putting together a strategy that keeps me class legal and gives me some hope of challenging a record.
