Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Calendar
Login
Register
Landracing Forum
Tech Information
Technical Discussion
(Moderator:
supercharger Speed Twin
« previous
next »
Pages: [
1
Go Down
Author
Topic: supercharger Speed Twin (Read 4869 times)
maguromic
on:
May 10, 2006, 01:33:47 AM »
One of my friends is interested in building a bike for a vintage supercharged 500cc class. He is using a 1954 Triumph T 100 Speed Twin and interested in Supercharging it.
He asked me to help but I am not a motorcycle guy and would not know where to point him.
He would like to know if some one like Drouin made a supercharger that was a bolt on or do you have to modify an old one? If you do where can he get a small enough supercharger for a 500cc?
Cheers
Blanding, Ut..a small dot in the middle of nowhere
Reply #1 on:
May 10, 2006, 11:48:42 AM »
Has he considered a turbo or does he have to use a supercharger in the vintage class?
Lakester Construction
My Bonneville Pages
1FATGMC
GeneF
Reply #2 on:
May 10, 2006, 08:10:01 PM »
I'm certainly not a Triumph expert, but I recently completed a t-100 flattrack/bobber build from a basket case 67 Tri.
During the course of the build I learned some of the frailties of the old Tri. 500 twins and would have to say they wouldn't be my first choice of a m/c motor to supercharge. Having said that, I applaude the desire to build something different and not follow the crowd ( ala Burt Munro )
Go to the following link and click on the Competition Board, there is a current thread running on supercharging the old twins including some interesting links.
Hope this helps.
P.S.- have your friend fill up his bank account and Good Luck!!
http://www.britbike.com/
Nortonist 592
Reply #3 on:
May 10, 2006, 11:07:09 PM »
Some years ago in England there was a guy running a blown Triumph. Not sure of the year but it was non-unit. He ran a shorrocks cabin blower and had all sorts of problems with the barrels lifting off the case. He solved the problem by taking two lengths of flat stock and two lengths of all thread. The flat stock went under the case and on top of the rockers and the all thread held the lot together. It sounds a bit Heath Robinson but it worked a treat.
Get off the stove Grandad. You're too old to be riding the range.
greg
New folks
Re: supercharger Speed Twin
Reply #4 on:
March 22, 2007, 10:22:45 PM »
Try TTS in Britain for a belt driven centrifugal blower. Drive sprockets will determine boost. Could also buy the smallest Eaton Unit from magnacharger and adapt.
sockjohn
Reply #5 on:
March 22, 2007, 10:31:02 PM »
If you decide to or can run a turbo, Garrett makes a tiny turbo for 400cc and up (50HP and up) but there is more to turbo sizing than that. GT1241
If you simply take a too large supercharger and change the pulley size to reduce the boost, it will still have almost (or as much) load on the engine.
bak189
Guest
Reply #6 on:
March 22, 2007, 10:40:17 PM »
The stock Tri. bottom end will not hold supercharging,,,,,and the barrel will lift off the cases............been there done that!!!!!!!!!!!!!!
1212FBGS
Reply #7 on:
March 23, 2007, 04:57:26 AM »
Hey i'm looking for a small "PEPCO" supercharger for the twim engine vesco liner resto.. any leeds
kent
Pages: [
1
Go Up
« previous
next »
Landracing Forum
Tech Information
(Moderator:
