Maybe someone else has already raised this point-- if so, I apologize.
A blow-through carb needs to be mounted in a sealed box so that its ambient pressure reference is the boost pressure. That said, the box makes it really a chore to make changes in the carb. Jets, power valves, accellerator pump cams, idle adjustments, etc all make it necessary to open the box. Time consuming and additional work.
I'm not saying a blow-through design isn't a good idea, just know what you are signing up for.
Regards, Neil Tucson, AZ
