Author Topic: moped ?  (Read 52681 times)
Re: moped ?
« Reply #60 on: December 24, 2012, 10:30:21 PM »
if I remember right, this same bike set a record at El Mirage at 38+ mph on Oct 10, 2007
Close.
P-PV
   Gerardi-Sloan-Romero-Manghelli    R. Yacoucci    11/07      39.648
PS. Entry names varied. Just depended on who filled out the entry. I filled out this one.
« Last Edit: December 24, 2012, 10:37:30 PM by desotoman »
Re: moped ?
« Reply #61 on: December 26, 2012, 03:20:53 PM »
I just got a self-propelled lawnmower for Christmas with a Honda GX160 engine in it.  I've taken one wheel off it and thinking of running Sidecar classes with it.
Re: moped ?
« Reply #62 on: December 26, 2012, 03:25:48 PM »
Okay, fine -- what's your point? :evil: :evil:
Re: moped ?
« Reply #63 on: December 26, 2012, 03:28:33 PM »
Just trying for a little humor . . .
Offline **RP**
Re: moped ?
« Reply #64 on: December 29, 2012, 06:59:05 AM »
"Maybe if the engine wasnt designed to be a motorcycle engine, it must not be a motorcycle."
I should not have posted that idea, it would eliminate MotoGuzzi Vtwins and that is not appropriate.
Modify button and my apology to the Guzzi riders.
JimL
It would eliminate the Honda Gold Wing too.....I think that was first designed to be a generator motor.
Ralph Pitlock
www.paintworkz.com
Offline Lem
Re: moped ?
« Reply #65 on: January 04, 2013, 04:23:46 PM »
Wow, a lot of assumptions made about my posts.
I waited patiently for a rule book before I posted again.  The reason I asked the question here in the first place was to avoid waiting for a rule book.
I simply wanted to know if the rule that required a motorcycle engine in motorcycle classes had been changed.  I was not "protesting" the record I mentioned, but since it is so clearly not a motorcycle engine - or even a motorcycle, I wanted a clarification.
A young man that used to work for me as a fabricator was asking me if I could build a version of the Jr Dragster engines that would be ok for LSR.  When I told him that it was "Motorcycle engines only" he whipped out his tablet & started showing me pictures of the A-PF 175 record holder in question.  That engine has never been installed in a motorcycle by a manufacturer.  The owner has made no effort to conceal the origin of the engine, so I wanted to know if a rule change had been made that would allow some different stuff to run at Bonneville.    That's it, nothing else. Since this was a moped thread, and the machine in question has pedals, it seemed like the appropriate thread to post in.
Someone here was gracious enough to give me contact info for Matt Shuss.  I e-mailed mr Shuss, and he stated clearly "We do not allow non-motorcycle engines".  good enough for me.
So it appears the the owner of that bicycle was either a better salesman than Joe Isuzu, or Stevie Wonder was doing a stint as a tech inspector that day.  I told my young friend that he can't run a Jr dragster flathead in a motorcycle frame.  I suspect he will keep working on his NASA car instead of heading for the salt.
Thanks to everyone that helped me out here.
B.
Re: moped ?
« Reply #66 on: January 04, 2013, 07:44:14 PM »
You've pointed out how easy it is for the motorcycle inspectors to police 1800(+?) classes.  That's why they get the big bucks; too bad they can't spend them.
Offline JustaRacer
Re: moped ?
« Reply #67 on: January 04, 2013, 11:30:05 PM »
My Cat B&S motorcycle ran OK.  So did a few hundred thousands of others.  Guess I was born in a different era or different income level than you guys.  At least I bought mine cash by mowing yards.
My doctor told me to go out and kill people.
Well, sort of.  He told me to reduce the stress in my life.
Offline Steve Walters
Re: moped ?
« Reply #68 on: January 05, 2013, 02:21:31 PM »
As it looks like this thread might be coming to an end, I would like to point out a few things, this is not for you veteran racers that know it all, it might help a few that read this thread and get confused as to how the tech process works.
First it is not up to the techs, or the SCTA to classify the bike or car.  When in tech, you are basically being checked for safety, the check off sheet helps with this process.  It does have a check off for, is the class designation and entry number displayed properly?  If the tech sees' something that is obvious out of class, he tells the team that if they make it to impound that could be a problem.  They do not run to a book that gives reference to every motorcycle engine ever made.
On tech day, when you are looking down a line as far as you can see of racers waiting to be  teched, it gets very intimidating, and when you have a lot of new entries that haven't done their homework, it gets very frustrating.  The best techs learn how to read the people they are teching, sometimes it is obvious that they are trying to steer you around something or get away with something.
If they make it to impound that is when proper build to class comes in, can mistakes be made, Yuuup.  Thats why the protest system is so important, sometimes a racer might run and hold a record thats out of class for several years, and finally it gets protested and has to get corrected.
1.B would have this particular moped run for time only, was it an intentional mistake, I hope not, Sh...t doe's happen.   :?
Wa's Bad Banana
B/CGALT
Offline Nortonist 592
    • http://www.artfv.com/design/fashion/
Re: moped ?
« Reply #69 on: January 05, 2013, 03:21:51 PM »
I'm pretty sure a  mistake was made.  The question is now what happens.  A non motorcycle engine has been certified for a record.  Cert., tag and trophy sent and record listed.  Will the record be removed?  If not does that mean the SCTA is now allowing non motorcycle engines in motorcycle classes?  If the SCTA is not going to allow non motorcycle engines then the record has to be removed.
Offline fredvance
  • FVANCE
    • Vance and Forstall Racing
Re: moped ?
« Reply #70 on: January 05, 2013, 03:42:39 PM »
You can ask tech to check your bike for class legality. I have done that when I had pushed the envelope. I have also been declared illegal after a quailfier. I miseterpeted(sp?) a rule. It was a quick, hacksaw, fix. :-D
Re: moped ?
« Reply #71 on: January 05, 2013, 10:09:17 PM »
I'm not saying that there hasn't been simular conditions when the record has been pulled. But it should be done in a manner that all parties involved get a fair chance to know what is going on and present there case, and defend their case, such as the protest in impound.
 Page 12 / 2012 RB / 1.H last paragraph Board of Directors.
Wa's Bad Banana
B/CGALT
Re: moped ?
« Reply #72 on: January 08, 2013, 08:08:00 PM »
T'would appear you will be running fuel.
Re: moped ?
« Reply #73 on: January 08, 2013, 08:26:28 PM »
How 'bout an exhaust deflector?  Give up a bit of power, maybe, but save your left thigh = and more important, a good portion of the family jewels.  Heat makes for genetic mutations.
"Don't point that thing at me unless you mean it!!" :roll:
Offline Lem
Re: moped ?
« Reply #74 on: April 30, 2013, 03:51:44 PM »
Just stopped by to see if this was ever answered...
