I have some grind-out and re-welds to do. Here's my excuse - I borrowed a friend's Miller 211 Auto-Set welder. It has this feature where you just set the material thickness, and it determines the wire speed automatically. It works great for flat, horizontal welds. However, when you get out of position, the welder doesn't know it, and keeps the wire speed constant (no adjustment).
After a while, I figured that out, and put the machine back in manual mode, which works fantastic. Lesson learned, and a little re-work to do, where the weld started to pile up and not flow out like it should.
