Hey, Tom -
Darn tootin’ it gets complicated!
There are issues of ram charging and extraction, swirl, squish that also play into this, and I’m not comfortable speaking to those, particularly in an engine I’m not familiar with.
I guess the general point I’m trying to make is that by using the larger ratio rockers, the biggest gains in airflow don’t come at wide open valve lift, but at partial lift. And that is still usable.
Let’s go back to your numbers, 212 @ .400, 220 @ .450, 225 @ .500. You mentioned diminishing returns, and yes, if you could push this valve out to .600, it’s not likely that you’d break 235 cfm. You’re close to maximum. If you think of it in terms of an ascending curve on a graph, you’re at the top on the right hand side, and flattening out.
What would be good to know is what the flow numbers are at .100, .150, .200, .250, .300, chart them on a graph, and then extrapolate what the flow figures would be if the valve opening were to be increased by 20% at each point – essentially shifting the graph.
The piston will be in the same relative position to the cam timing, but the valve will be open 20% more. At .120 versus .100, you’ll see a lot of potential for better flow, at .180 versus .150, the effect will be a little less dramatic, but still to the plus, etc.
So during the entire intake stroke, overall flow potential is higher, yet the valve still opens and closes at the same points on the intake and compression stroke.
The greatest potential to achieve better flow is actually between the point that the cam starts to open the valve until you meet that point of diminishing returns toward a wide open valve.
If it doesn’t cause the valves to get too comfy with the pistons, or the springs to buckle, I’d try the larger ratio rockers. You’ve already got ‘em!
