Maybe I wasn't specific enough in my last post about servomechanisms-- it is not necessary to use a computer to adjust a wing so that it provides a constant downforce. Here's how to avoid using any computer at all:
1. Sense the position of a rear upright in relation to a fixed point on the chassis; this change in length will be proportional to the rear spring compression-- which is a function of downforce.
2. Amplify the difference between that sensor output and an output from a voltage reference.
3. Apply the amplified difference voltage to a power amplifier capable of driving a DC motor or linear actuator connected to the wing.
4. The feedback from the sensor will drive the motor to adjust the angle of attack so it will keep the ride height constant-- providing the feedback is negative. If it isn't, just reverse the two wires to the DC motor.
5. The ride height can be adjusted to be the same as the static ride height (no downforce) at speed, lower ride height (downforce), or higher ride height (lift) by setting the reference voltage.
6. Use enough gain in the amplifier so that the loop error is small but not so much gain that it is unstable (oscillates). This is a simple feedback control system but it can be made a bit more complicated by adding integrators and differentiators to form a "PID" loop.
7. At rest or at low speed, with the reference set for downforce the wing will be at maximum angle of attack because the servo is trying to get downforce without any air passing over the wing. As speed increases the wing will assume whatever angle it takes to generate the downforce that you've asked for.
Voila! ...no computer. Now whether this would be legal is another matter.
Regards, Neil Tucson, AZ
