Wouldn't it be better to use the computer to collect downforce data and manually adjust as speed and traction require.
I would expect you would need 3 computers dedicated to flap control if you went that way. A primary, a secondary and one to ensure they were in agreement prior to moving the surface. If you don't think it is necessary, maybe a little overkill, check into fly by wire airplanes. You might want to do a little analysis into worse case malfunctions, oscillations, how to control and filter them.
