Author Topic: Fuel pressure gauge  (Read 9027 times)
Re: Fuel pressure gauge
« Reply #15 on: October 14, 2012, 05:53:04 PM »
I think you said you were running a magneto. Providing that's the only electrical in the car then just install an external switch to ground the mag.
Offline JoeBlystfk
    • Bonneville 2012 City of Burbank Streamliner 60 years
« Reply #16 on: October 14, 2012, 05:59:26 PM »
Perhaps the rule should say that   :-D
Offline jdincau
« Reply #17 on: October 14, 2012, 07:34:03 PM »
The rule says what it means, you must have a battery cut off switch. No battery, no switch required. As has been discussed at length here before the idea is for the first responders be able to cut all electrical power before they start extraction procedures on the driver.
« Reply #18 on: October 14, 2012, 07:53:52 PM »
I think they need a impact switch as well.
« Reply #19 on: October 14, 2012, 09:32:33 PM »
That would be for an electric fuel pump, but Joe mentioned a mechanical pump.
I agree with Hotrod - if all you're running for electrical is a magneto with a mechanical fuel pump, there is the potential for a situation where you're unable to shut it down.
