Author Topic: Classic Gas Coupe - engine rules question  (Read 4910 times)
Offline 12go3az
« on: September 20, 2012, 04:48:37 PM »
I got asked this question.
  EXAMPLE - 1981 or older camaro could use MSD style ignition & carb. or any mechanical fuel injection  & be legal.
                   from rule book I'd vote LEGAL.
                   what if U put in a late model LS  series engine ,  crank triger, coil near plug, efi,  & use GM ecm to control ?
                    LEGAL  -  NOT LEGAL ??   If not legal for CGC what class would it fall in?
Offline thundersalt
Re: Classic Gas Coupe - engine rules question
« Reply #1 on: September 20, 2012, 05:13:05 PM »
My guess is the crank trigger and coil pack  can stay but the ECM  and efi have to go.
« Last Edit: September 20, 2012, 05:14:57 PM by thundersalt »
916 REMR
El Mirage 200 MPH Club
Offline jacksoni
« Reply #2 on: September 20, 2012, 05:51:31 PM »
Agree, but in your first example, what makes it a GC? Need engine swap (LSx counts), quick change or non stock blower in the first place. Point of classic is, few cars before 1981 had EFI (sure some did) but you need to use that original EFI if so. At least that is way I read the rule.
Jack Iliff
 G/BGS-250.235 1987
 G/GC- 193.550 2021
 G/GMS-182.144 2019
« Reply #3 on: September 20, 2012, 06:24:42 PM »
There are crank trigger setups without "sensor controls"?
Offline 12go3az
« Reply #4 on: September 20, 2012, 07:30:46 PM »
After burning my day on this question   (should be working on the comp-coupe)
   I think! #1  1981 & older camaro  makes it classic & can NOT have EFI.
               #2  would have to be 1982 or newer for altered or gas coupe??
               #3  told QUESTIONER buy a rule book, read & I need to get back to work
               #4  NEVER LEAVE THE SHOP DOOR OPEN WHEN U GOT TO GET WORK DONE1
                                          JIM
Offline will6er
« Reply #5 on: September 20, 2012, 11:21:15 PM »
re: #1
I believe you can elect to be in the "Modified Category"
re: #2
It can be any year after 1949 IF it does not meet the "Classic Category" limitations. (pg. 72)
Will
Offline RichFox
« Reply #6 on: September 20, 2012, 11:50:18 PM »
I believe it can be any year after 1928 unless it has a Vintage engine.
Offline jacksoni
« Reply #7 on: September 21, 2012, 08:19:52 AM »
                                          JIM
#1- an 81 and older Camaro with EFI runs in regular, not Classic, Production, or Modified category depending on what other modifications, body or engine, are made. Modified contains GC, Alt and CC and all the engine/fuel/blown or not categories therein.
#2 Incorrect
#3&4- good plan  :-)
Jack Iliff
 G/BGS-250.235 1987
 G/GC- 193.550 2021
 G/GMS-182.144 2019
Offline jimmy six
« Reply #8 on: September 21, 2012, 10:18:16 AM »
U need 3 rule books.
#1. Take to work. (lunch box) etc.
#2. Coffee table in front of TV (quick referance)
#3. The bathroom (most imporant one)
