Author Topic: Mark Williams coupler  (Read 4326 times)
Offline Rick Byrnes
« on: August 28, 2012, 11:57:02 AM »
Used only 6 passes & decided I wanted suspension.
MW 32 spline 1.375" shaft
MW 40603A for 10spline rear. V8 or midget center
MW 40640A female coupler
MW 40780 male coupler
2 stainelss lock rings and 2 4130 lock rings
All parts except the lock rings are Non-Electrolitic Nickle plated
(no hydrogen embridlement)
Want $300
Rick@RBMotorsports.com
Rick
Re: Mark Williams coupler
« Reply #1 on: August 28, 2012, 12:00:33 PM »
Rick what  is the length?
Offline Rick Byrnes
« Reply #2 on: August 28, 2012, 12:24:44 PM »
HI Glen
only 8 inch length.
Rick
« Reply #3 on: August 28, 2012, 04:25:53 PM »
Rick,
What material is the shaft?
What is the trans coupler?
Where are you measuring the 8"?
Offline Rick Byrnes
« Reply #4 on: August 29, 2012, 01:11:25 PM »
Sid
8 inch is overall length.
I'm guessing the shaft is 4130 which is their base alloy, but I didn't originally purchase the parts.
Trans is Jerico 4 spd clutchless and I think is 32 spline.  I will go out to the shop and count.  First I need to cut the grass which will keep the little red haired girl happy.  Later today.
Rick
« Reply #5 on: August 29, 2012, 04:22:11 PM »
My front one is 13" but it might fit the rear. I'll be putting the B&J back in to check length while you're on the grass.
Offline Rick Byrnes
« Reply #6 on: August 29, 2012, 09:31:56 PM »
Sid
The trans coupler is 32 spline, but about .010" smaller diameter than the shaft and other parts which of course makes the splines a little finer.  When I replaced the coupler, I ended up with a real bastard flange for u joint and 2 piece shaft.  Kinda like a 4WD front shaft.
Hope this helps
Rick
« Reply #7 on: August 29, 2012, 09:45:27 PM »
Sent you a pm.
Offline Rick Byrnes
« Reply #8 on: February 26, 2013, 11:05:30 AM »
bump
Rick
« Reply #9 on: February 26, 2013, 11:14:00 AM »
Rick, thanks for shooting me a note. I will look at my stuff and see if this will work tonight.
