No problem- we made I think 17 passes chasing stuff ( a fuel pressure regulator that was not locked down so dropping pressure every run, and then a miss at high speeds that was a coil (or two). Have spent a lot of time, effort and of course $ trying to get the engine to run the same as 08 and 09, with little luck. Exact same configuration, fuel/ignition map etc the only slight difference being location of air intake on the front, which of course could be a factor. But problem has been in two different cars as well. I have a line on the problem and will see when that is investigated further. Will try to get the car ready for spring at Wilmington but likely will not be at 2013 with it (big vacation trip right before and effort toward Udo's Bonneville Bugeye which we ran in 2010. He has a nice little D motor to go into it.) Appreciate the offer. Put up some stuff in a build diary. Would like to see what you do.
Oh, and the guys at A2 are great. We learned a lot with our time there.
