Author Topic: Legal seat?  (Read 14351 times)
Offline robfrey
    • carbinitelsr
Legal seat?
« on: July 28, 2012, 04:36:32 PM »
Is this seat legal for our #3838 A/BGT Vette? It not that we are too cheap to change it, it's that is really mounted well and us going to be a lot of work to change it.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
Re: Legal seat?
« Reply #1 on: July 28, 2012, 05:33:51 PM »
How thick is the padding, 1" is max allowed, is it fire retardent? Have you run it by the SCTA tech. committee?
Offline robfrey
    • carbinitelsr
Re: Legal seat?
« Reply #2 on: July 28, 2012, 06:54:47 PM »
We are good on the 1" max padding.
I have not run it past the tech committee yet.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
Offline Cajun Kid
Re: Legal seat?
« Reply #3 on: July 28, 2012, 06:55:12 PM »
I hope it passes, you should place a helmet in there flush against the headrest, if the head support sides of the seat go as far forward as the leading edge of the helmets chin bar then it meets "that part" of the rule,, the rest would be padding, material and mounting rigidity...
like this ?
Keep us posted.
Charles
ECTA Record Holder Maxton
OHIO
B/CGALT, C/CGALT
Offline robfrey
    • carbinitelsr
Re: Legal seat?
« Reply #4 on: July 28, 2012, 07:14:42 PM »
My buddy has my 2012 rule book and is on vacation. Killing me!
What does it say about max side to to side helmet movement?
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
PatMc
Re: Legal seat?
« Reply #5 on: July 28, 2012, 07:26:06 PM »
Very cool.  Got it set up for T1 SCCA?
If you dump the seat, let me know.  C5?
« Last Edit: July 28, 2012, 07:33:20 PM by PatMc »
Re: Legal seat?
« Reply #6 on: July 28, 2012, 07:30:06 PM »
2" each direction max, 4" total.
Offline RidgeRunner
Re: Legal seat?
« Reply #7 on: July 28, 2012, 07:33:41 PM »
2012   page 25   3.A.3  Driver's Helmet Support:
A forward, side, and rear helmet support system shall be used in all vehicles.
Forward movement:  all cars and motorcycle streamliners shall have an engineered and tested SFI spec 38.1 type head and neck restraint system.
Lateral movement:  The seat, roll cage structure or suitable restraint system, such as a restraint net, swing away bar or similar such device, shall provide restriction to lateral head movement of less than 2 in. per side inclusive of structure deflection, and at a minimum extend to the forward most portion of the helmet see Section 3.B.1.
Offline robfrey
    • carbinitelsr
Re: Legal seat?
« Reply #8 on: July 28, 2012, 07:47:04 PM »
I'm guessing that this disqualifies the seat.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
Offline Cajun Kid
Re: Legal seat?
« Reply #9 on: July 28, 2012, 08:57:27 PM »
By the definition of the rule this would not pass...looks like you are an Inch short on side support length..
You need to modify the seat head side supports (you may not have to replace the seat)  just add to the side restraints so that from the pic you took the chin bar would be equal too or behind the leading edge of the seats helmet side supports.
Good luck,
Charles
« Last Edit: July 28, 2012, 09:00:16 PM by Cajun Kid »
OHIO
B/CGALT, C/CGALT
Offline Cajun Kid
Re: Legal seat?
« Reply #10 on: July 28, 2012, 09:01:51 PM »
You may send a pic to the tech committee for your class,,, it is sure close (but not exact as the rules read) hmm I hope it is the same lenght or longer on the right side (looks like the right side is shorter) that may be an angle or optical illusion.
Charles
« Last Edit: July 28, 2012, 09:03:30 PM by Cajun Kid »
OHIO
B/CGALT, C/CGALT
Offline thundersalt
Re: Legal seat?
« Reply #11 on: July 28, 2012, 10:13:10 PM »
Building an extension would be cheaper than changing the seat (and easyer)
916 REMR
El Mirage 200 MPH Club
Re: Legal seat?
« Reply #12 on: July 28, 2012, 10:17:05 PM »
You should always have at least 3 rule books. One for the shop, one in you day driver and one in the bath room AKA the racers library. :cheers:
PatMc
Re: Legal seat?
« Reply #13 on: July 28, 2012, 10:33:34 PM »
Or, I took tubing, and mounted in to the top of the rollcage, coming down on each side, but made it removable for street driving, or other kinds of competition.  It took about 4 hr and $50, mostly the SFI stickered padding.
Offline gray63
Re: Legal seat?
« Reply #14 on: July 29, 2012, 09:43:23 AM »
We built an extension on our full containment seat, using square tubing. It proved
to be the best solution for us on the 56 Corvette.
Dave #3611
Carlisle, Pa.
