Author Topic: wanted 6 spline V8 quick change gears  (Read 4241 times)
Offline turborick
  • Go as fast as we can with as little as we can
    • http://www.bonnevillestreamliner.com
« on: July 25, 2012, 05:28:26 PM »
Looking for a #2a 6 spline V8 quickchange gear. winters don't make the 2a anymore. need one bad for speedweek
Rick Yacoucci
The new Nebulous Theorem 3.5 #788
Online jdincau
Re: wanted 6 spline V8 quick change gears
« Reply #1 on: July 25, 2012, 10:12:41 PM »
I don't have that set, have you tried
http://www.1speedway.com/Quick_Change_Gear_Charts.htm
Offline fwillyj
« Reply #2 on: July 25, 2012, 11:28:21 PM »
-here's a link to a 1" wide #2 set for $65---don't know what a 2A set is.
-winters shows all the 6 spline stuff in two different widths---but no 2A sets.
http://pitstopusa.com/i-5081098-winters-4400-series-6-spline-quick-change-gears-midget-8-3-8-ring-gear-1-wide-set-2.html
Offline RichFox
« Reply #3 on: July 26, 2012, 12:06:45 AM »
Yeah. My chart shows a #2 set. 23 and 24 teeth. I believe I have that one. Is that what you are looking for?
Offline turborick
« Reply #4 on: July 26, 2012, 12:26:56 AM »
gearset #2A   17 and 18 teeth 1.059 spur ratio
if you look at the older gear charts the 2A shows up then in the newer ones it's gone
Rick Yacoucci
Online jdincau
« Reply #5 on: July 26, 2012, 08:19:34 AM »
Check out my link above, Speedway engineering in Sylmar still shows it in their chart
Offline turborick
« Reply #6 on: July 26, 2012, 09:45:04 AM »
Yea I tried Speedway.... that's were I normally get my gears from
Rick Yacoucci
Offline RichFox
« Reply #7 on: July 26, 2012, 09:53:13 AM »
I will check with Norm Rapp this morning
Online jdincau
« Last Edit: July 26, 2012, 10:38:14 AM by jdincau »
Offline turborick
« Reply #9 on: July 26, 2012, 10:40:01 AM »
I didn't know about the Quarter master gears.... they make a 2A with a 35/37 tooth count and almost the same gear ratio 1.057 vs a 1.059
will call them
Rick Yacoucci
Offline RichFox
« Reply #10 on: July 26, 2012, 03:22:01 PM »
No luck at Norms.
