Author Topic: Drive shaft diameter  (Read 13260 times)
Re: Drive shaft diameter
« Reply #15 on: July 18, 2012, 12:04:14 PM »
This is a second car -- not a redo of the one we all are fond of.
Offline Billy @ AHG
« Reply #16 on: July 18, 2012, 12:26:33 PM »
Holy cow !  Totally sick ! Cant wait to see it .
Salt Junkie
« Reply #17 on: July 18, 2012, 02:11:34 PM »
I guess living way out in the sticks, not in the big city, makes you narrow-minded.
Offline dw230
« Reply #18 on: July 18, 2012, 02:57:04 PM »
I would guess that the artist in Jeff played a part of this build.
Offline Richard 2
  • 2 Richards Racing
« Reply #19 on: July 18, 2012, 08:48:10 PM »
COOL, THAT'S ONE MEAN LOOKING RIDE. I can appreciate the metal work.
Richard
4 cylinder Esslinger
Could of had a V8
Offline Jeff Brock
  • XO/GCC
« Reply #20 on: July 18, 2012, 09:54:03 PM »
Oh... YUGO Stan ... those are pretty early , mock up shots. I guess we get the idea,thank you.
I am on break tonight from 2nd.shift (I am a solo studio again, chased off all the poor help)
I think I figured out how to upload a shot of the cock pit :
complete steering : check
driveshaft assembly : check
trans. & shifter : check
BROCK ART SPEED
« Reply #21 on: July 18, 2012, 10:44:13 PM »
Jeff --
First -- I've got to get my Wennerberg easy translation manual for Yugo.  Most I can figure out.
Second -- isn't there a difference between a cock pit and a cockpit?
Stan
Offline maguromic
« Reply #22 on: July 19, 2012, 12:34:53 AM »
Stan
Only if you have been to Thailand.  :-o Tony
Offline Jeff Brock
  • XO/GCC
« Reply #23 on: July 19, 2012, 01:24:08 AM »
Jeff --
Stan
Stan --  Hello ! ... obviously, I was thinking with my Toronado. geez, read the manual.
* speaking of ... I set RIGHT over the front U-joint. I mean like 1.5" below my butt. I have 1/4" steel plate and the seat pan between us.
 Enough?
 I've heard some driveshaft "war" stories.
BROCK ART SPEED
« Reply #24 on: July 19, 2012, 01:55:28 AM »
Never enough when you hear things start to let go!!!  :evil: :evil: :evil:
Definitely looking interesting.
« Reply #25 on: July 19, 2012, 07:21:11 AM »
When I saw the pics i thought  ...jeez, gutsy effort cutting THAT car up, phew, it's another one.
Looks fantastic!!! :cheers: :cheers: :cheers:
Yeah,I'd be having a fat piece of plate under that seat too. :oops:
Offline Jack Gifford
« Reply #26 on: July 20, 2012, 01:27:14 AM »
... I set RIGHT over the front U-joint. I mean like 1.5" below my butt. I have 1/4" steel plate...
In my blown alky minipuller I sat right over the shaft and almost that close. NTPA rules required complete 1/4" steel shielding substantially attached to the chassis at front and rear (only 16" apart in my case). But in my mind, the key aspect of the rule was that the shield inner diameter be round and smooth. Do you have room for a complete round shield?
M/T Pontiac hemi guru
Offline Jeff Brock
  • XO/GCC
« Reply #27 on: July 20, 2012, 01:52:40 AM »
Hey Jack, thanks for the input.  I have built a front u-joint / front shaft section, round sleeve, 1/4" steel tube, right at the "business" section (under my butt) that is pretty darn safe feeling / looking. it is 2 1/2 times wider than the SCTA requirement. with a solid 1/4" plate beneath my seat.
Then I shrowded  the balance (rear section) in a rectangle tube.
 I am not as worried about this application, as I would a high revin, real horse power situation.
I am hoping to get all I need done at 5500 rpm, with a couple 6000 shift spikes along the way.
Buick straight 8 -- later model 5 speed -- 25.5" drive shaft.
Thanks again, I think we're on the same basic page.
BROCK ART SPEED
Offline Jeff Brock
  • XO/GCC
« Reply #28 on: July 20, 2012, 01:59:20 AM »
Here's a progress shot  (before I rebuilt and balanced the shaft)
Another 1/4" plate goes over this.
BROCK ART SPEED
