Author Topic: Wheel speed sensors  (Read 12085 times)
Offline jdincau
Wheel speed sensors
« on: June 27, 2012, 11:13:22 PM »
Anyone have pictures or descriptions of wheel speed sensor instalations? I mean non stock custom install not factory ABS or traction controll.
Offline maguromic
Re: Wheel speed sensors
« Reply #1 on: June 27, 2012, 11:40:19 PM »
There are many ways to do it, but here is a simple one.  Tony
Picture from the net
Offline rgn
« Reply #2 on: June 27, 2012, 11:42:46 PM »
This is a bike set up obviously, the magnet is glued to the disc and the pick-up glued (sikaflex) and cable-tied to the fork leg.  Minimum clearance between the the magnet and pick-up.  The unit is a trail tech Vapor.  It allows me to monitor mileage for oil change and service intervals, more than telling what speed the bike is doing, though it does do that also.
http://trailtech.net/vapor.html
« Last Edit: June 27, 2012, 11:45:57 PM by rgn »
Offline jdincau
« Reply #3 on: June 28, 2012, 12:03:46 AM »
Tony, that is perfect, what does the sensor react to in the pictured install you posted, the vanes in the rotor?
« Last Edit: June 28, 2012, 12:06:33 AM by jdincau »
Offline maguromic
« Reply #4 on: June 28, 2012, 12:21:55 AM »
This is from that particular  sensor manufactures website.
"This sensor can pickup up a signal from any metal bolt. The most common installation for the Speed sensor is to point the sensor at the bolt(s) that hold the Brake Rotor or Wheel Hub on. If you have a stock car, this is the most popluar installation on wide five, or 5 on 5 wheels. An alternative method on some racecars is to attach a bolt to the rotating hub and have it pass by the sensor".
There website is http://www.advantagemotorsports.com/Sensors.htm  about half way down on the page.
On the cars I am helping build we are picking up from a rotor bolt, though our mounting is a little more complex due to our shrouds for the inside of the  wheel. Tony
Offline Jon
« Reply #5 on: June 28, 2012, 01:36:29 AM »
Does anyone have experience with a good 3 wire 5 volt feed analog sensor they would recommend?
My old 02 data logger doesn't do frequency inputs.
Thanks
jon
Underhouse Engineering
Offline Dean Los Angeles
« Reply #6 on: June 28, 2012, 01:00:57 PM »
Any proximity sensor will work.
If you are data logging a single pulse per rotation will do.
In any case you have to do the math, and it won't tell you a thing about tire growth.
If you want to use it for active feedback, then you are going to need a dozen pulses per rotation or more to get feedback you can use.
« Reply #8 on: June 28, 2012, 03:13:04 PM »
John Burk,
That is pretty trick stuff!!
BTW: Are we going to see you AND your car this year at Speed Week??
Offline John Burk
« Reply #9 on: June 28, 2012, 10:54:31 PM »
Almost but not quite . Health problems slowed me down recently . Next year for sure .
« Reply #10 on: June 30, 2012, 10:10:50 PM »
Here's the one I just added to the Bockscar's left front wheel to hook up to the Motec I am installing.  It is a 3 wire hall effect, the slightly modified 1/4 inch bolt next to the sensor is the signal generator... basically a single gear tooth to count wheel rotations.  If I calibrated it right the speed will show up in the internally recorded Motec data.
Offline johnneilson
« Reply #11 on: July 01, 2012, 06:09:14 PM »
Another way of placing speed sensors is to put it on the drive shaft.
It somewhat simulates a multiple mag/bolt on the wheel and does infact takeinto account wheelspin from either wheel (rear).
Used to help monitor LSD units on RR cars.
« Reply #12 on: June 26, 2017, 12:20:42 PM »
UPDATE
 :-o
What is the difference between a 2 wire and a 3 wire pickup?
Offline Dynoroom
« Reply #13 on: June 26, 2017, 12:36:19 PM »
Hall effect or magnetic. Depends on what you are using to record with.
Offline jdincau
« Reply #14 on: June 26, 2017, 12:40:57 PM »
Here is the spec for the 3 wire I am using it is a hall effect with a power, ground and signal output. The 2 wire type is just an on/off switch activated by a magnet.
