Author Topic: Gas coupe radiator  (Read 2794 times)
Offline azgearhed
  • 1979 Z-28 AA/CBGC & AA/CGC & AA/CBGALT
Gas coupe radiator
« on: June 23, 2012, 07:43:17 PM »
I have a question regarding gas coupe radiators. I want to use a crank-driven Pro Charger on a CGC. The blower will need to be mounted off the crank damper and will be forward of the stock radiator location by 6"-8". Can I tunnel the radiator for clearance or use two smaller rads on each side of the blower? Are there other options?
BC Racing 1979 Z-28
AA/CBGC Record 251.802 Speed Week 2012
AA/CBGALT Record 255.382 Speed Week 2013
AA/CBGC Record 226.104 El Mirage Sept 2015
AA/CBFALT Record 227.954 El Mirage June 2016
AA/CBGC Record 267.878 Speed Week 2018
AA/CBGALT Record 236.458 El Mirage Nov 2016
It's a lot of work to have fun...
Offline Dynoroom
Re: Gas coupe radiator
« Reply #1 on: June 23, 2012, 08:31:59 PM »
Sorry, but by your discription I'd say no. An opening in the radiator core or two smaller radiators defeats the purpose of the rule. Can you move the core forward 6"?
Otherwise it looks like Alt. class.
LittleLiner
« Reply #2 on: June 23, 2012, 10:31:43 PM »
I doubt you can move the core forward and still be legit for Gas Coupe. The rule says the radiator must be " . . mounted in the original location as the OEM radiator . . "
Maybe there is some other option for mounting the blower elsewhere . . . or . . . can you move the engine back?  You are allowed an engine "setback" of 2% of the wheelbase.
What engine and chassis are you going to be running?
Offline azgearhed
« Reply #3 on: June 24, 2012, 11:33:16 AM »
Yeh-I think the only option for using the Procharger is to convert to belt drive
BC Racing 1979 Z-28
