Author Topic: Radius rod lanyards  (Read 5042 times)
Offline JoeBlystfk
    • Bonneville 2012 City of Burbank Streamliner 60 years
Radius rod lanyards
« on: June 18, 2012, 07:55:52 PM »
Any idea why you would be required to have a lanyard on the radius rods in a car with everything enclosed inside the body  ?
Offline Dynoroom
Re: Radius rod lanyards
« Reply #1 on: June 18, 2012, 08:05:16 PM »
To keep them from going through the body.
Offline JoeBlystfk
« Reply #2 on: June 18, 2012, 08:30:56 PM »
Not trying be a smart a .., but they would do that how ? If for some reason one broke wouldn't it simply fall down inside the car ? Ours are one inch tube with a heim on each end. I can't imagine it coming out through the body if the heim or tube broke.
Offline Dynoroom
« Reply #3 on: June 18, 2012, 09:01:06 PM »
Sorry, I was a bit quick, but all the same, if the rod breaks on the leading side the SCTA worries that it can pole vault or damage the surface. I understand your thoughts but that's the reason.
« Reply #4 on: June 18, 2012, 09:15:40 PM »
Joe, send a couple of pictures to the rules committee at SCTA so they can offer a way to contain the radius rods if one breaks. Could be a cable loop or a retention device like we use for drive shafts.
Offline NathanStewart
« Reply #5 on: June 18, 2012, 11:53:41 PM »
Would you rather get into a discussion about it with an inspector or spend $5 and 5 minutes putting some braided cable around the links and then having the inspector check the box without having to say a thing about it?
El Mirage 200 MPH Club Member
Offline Buickguy3
« Reply #6 on: June 19, 2012, 09:43:32 AM »
    Are you guys reading something printed in the 2012 rule book that I can't see. What page or rule # is it? I only see reference to the large washers on the heim joints.
                   [America]
« Reply #7 on: June 19, 2012, 10:44:31 AM »
I agree with Nathan---most of the time it is not worth the effort to get a written variance into your log book---but if you must get something in WRITING to put in your log book  8-)
« Reply #8 on: June 19, 2012, 11:22:58 AM »
Doug, look at 3.S. Wayno
Offline Buickguy3
« Reply #9 on: June 19, 2012, 12:18:29 PM »
  Wayno, I guess I was reading it as the radius rods on the front axle, not the rear. I guess that's why I didn't see any rule or reference. I'll go back to sleep now.
                   [America]
Offline fastman614
« Reply #10 on: June 19, 2012, 12:36:09 PM »
This actually is a valid question ..... the reason for this was originally intended to stop the split wishbone (or any ladder bar type) radius rod from angling downwards (under the power of the rear axle winding downwards) and pole vaulting the car - & digging up the salt in the process. While I agree that on a four link type suspension, the likelihood of a link bar ripping through the body may be a "longshot" possibility, the rules are there as written because, in the absence of a rule, most competitors would NOT put a method of limiting the travel of a broken link bar on to their cars.... it has, apparently, over the years, been demonstrated that  body metal, secondary flooring, step-pans etc simply are not, at times enough to hold broken link bars back. Now, if the body was 1/4" thick steel in that area and rigidly mounted so as to, in and of itself, comply with the rules as written, you could make a valid case for the body being the retaining device. Do document thicknesses with pictures etc though.....
« Reply #11 on: June 19, 2012, 02:50:48 PM »
^^^ EXACTLY what I was going to say.
