Author Topic: Modified Class Wheelbase  (Read 5096 times)
Offline maj
Re: Modified Class Wheelbase
« Reply #15 on: April 11, 2013, 04:57:51 PM »
My interpretation would be if its classed as M and you change sprockets , run a record and the wheelbase is found to be too long the record would be disallowed .
Up to you to make sure it complies
Offline ol38y
« Reply #16 on: April 11, 2013, 09:10:05 PM »
Larry,
the front fender rule was radicaly changed a few years ago and has been a non-issue since it was.
Except that when they came out with the front fender mandatory rule, in 2010 I believe, I saw a couple bikes in line with no front fender.
Larry Cason
2010 BUB 1350 M-PG record
