Not the way I read it. If the factory documentation says 50", (regardless of where the axle is located in
the slot when measured by the factory) you are allowed 55" max measured at the rearmost position. So
the smallest rear sprocket you want to run will have to be adjusted at or below that 55".
Have you set your ride height where you want it? Like you said, those longer forks increased the
wheelbase, so shorter forks should reduce the wheelbase.
Cheers, Dave
