JL 222 What size plumbing and what size water pump for inter coolers?
Hi SPARKY... Fuel
We run parts wash
Fuel guys don't use intercoolers because of the big amount of laten heat of evaporation which cools the intake charge. Plumbing is 11/4 clear plastic tubeing from Home Depot. Mezierre dual outlet 55 gal per min water pump. costly s.o.b.
1 12 X 12 Procharger intercooler with dual inlet and outlets. Water flows into the middle of front tank flows to back and out at top of back tank. Air flows in at front tank bottom, up through intercooler and out through top
tank front. Temp is taken at top of tank. Intercooler tank is 38 gal and we usually put in 6 bags of ice but are planning on
using more ice.
Our 294 mph 1st mile time took 114 sec from 1st applying throttle, after 30 sec tps 39%- boost 15lbs temp 97 deg.
My chart for a 70 deg day at 25 lbs and 65% efficiency shows 335 deg
75% 299 deg
100 deg day 380 deg
345 deg
Our 130 deg at 26 lbs is pretty good, consider also you start out about 2psi less at bville =28lbs and the temp was closer
to 90 deg
I don't understand this resistance you mention as the air and water are separated from each other.
