38... I ussually start with FUBAR and replace and rebuild until I get something decent. Sometimes its just an expensive FUBAR in the end.
Bob:
I understand about no electronics. That is clearly stated in the rule book. That also makes the tubro option a challenge. Manually adjusted pop-offs and waste gates present serious challenges over electronically controlling these functions. We plan on spending a lot of time on the dyno working through the tune up.
My other concern is dumping the exhaust out of the fenders verus under and out the back of the car. I know this topic has been covered in other threads but I plan on looking that topic up as well.
38 sorry to hyjack the thread. Good luck with the conversion.
Hey Bill how ya been?
Mike Reichen here. I met you at Maxton last year I believe. I drive the evo 2 mitsubishi.
Are you still working with Matt?
If so I would follow his lead. The turbo setup can be made to work in what ever situation you need. ie class, engine size, hp output, effieciency you need. Making it work without electronics shouldn't be any real problem it may just take a little longer.
38flattie- 1st off good luck with your project.
1 thing you need to understand is that all boost pressure is NOT equal. You can make 100 hp or 1500 hp at 14.2 psi.
If you are shooting for a particular hp # so as not to over strain your engine you need to pick a turbo that will get you there in the most efficient manner and then comes the hard part( don't turn it up as there will be a whole lot more power there just waiting and tempting you) You need to deal with a specialist when deciding on a turbo for your set up as they can be tailored to do just about anything you like but if you deal with the wrong person they can make your car an under performing not fun to drive pile.
The rite turbo will make more power and be easier on your engine at the same time.
P.S.-I thought this was SPEED week not a car show.
Do you want to go fast, or look cool ( a blowwer sticking through the hood= cool, not so good for aero though.
Mike Reichen
