Author Topic: Roadster pick up in STR?  (Read 52025 times)
Offline zenndog
« on: April 16, 2012, 12:38:15 AM »
Has anyone ever run a 26/27 roadster pick up in street roadster? Would it be allowed?
Offline NathanStewart
Re: Roadster pick up in STR?
« Reply #1 on: April 16, 2012, 01:14:32 AM »
Yes, a T RPU would be allowed.  I've seen few A rpu's run in STR before but there's no reason why you couldn't run a T.
El Mirage 200 MPH Club Member
« Reply #2 on: April 16, 2012, 11:15:42 AM »
It sure would make it hard to get a lot of the driver out of the wind with the short passenger compartment.  I'd guess it would be harder than the 26-27 roadster, a few of which look like they're hauling an oil-drilling rig.
Stan
« Reply #3 on: April 16, 2012, 03:24:00 PM »
Cword here and on the HAMB is part of the North of the 49 Crew and they run a roadster pickup.
« Reply #4 on: April 16, 2012, 03:51:22 PM »
Their website http://1149.ca/ hasn't been updated for several years.
Believe they are now running a B/GRMR (see last year's results):
18  1149  N49 Racing  B  GRMR  0.000  230.192  Ted Allan
« Reply #5 on: April 16, 2012, 05:12:39 PM »
Yeah the RPU was set aside but I think Mike mentioned they were going to dust it off?
Offline n49racer
  • Faster Faster
« Reply #6 on: April 17, 2012, 10:33:23 AM »
Hi everyone. Yes we ae running the B/GRMR now but the RPU is in the garage. After the Jesel boys bumped our record in B/GSTR we didn't know if the RPU would be slippery enough to challange. We felt the step from the cockpit down to the top of the box was a negative. The cramped cockpit was a problem as we had to sit more out in the wind than we liked, of course being 250 Lbs had nothing to do with it.
We had a bit of a problem trying to get enough weight forward. When the car was built it weighed in at 2600#s with the bias being 65/35. When we stopped using the truck it was 4200#s which put us at about 55/45. the truck did like more weight forward.
B/STR  209.97 best
B/RMR  248.45 Record Holder 2012
B/FRMR  248.85 Record Holder 2012
2 club member 2012
« Reply #7 on: April 17, 2012, 10:36:24 AM »
Thanks for the details!
Offline zenndog
« Reply #8 on: April 17, 2012, 12:17:44 PM »
Thanks for the comments and the details about your truck.
I was wondering about the model T cockpit size restraints. and the other issues regarding the way the bed fits the body. Which are similar issues to the model A truck.
« Last Edit: April 17, 2012, 12:49:17 PM by zenndog »
« Reply #9 on: April 17, 2012, 12:34:37 PM »
One thing sure to be checked would be the bed height in relation to the body.  Be prepared to substantiate that.
Offline zenndog
« Reply #10 on: April 17, 2012, 01:00:08 PM »
I have a 26/27 real steel body. I hope it meets the specs.
Why don't they just tell us in the rule book what grill shell we have to use? What is grill 530 sq inches? I assume it is a 32. But I guess that it is a bobbed 32 grill, so bobbed how much?
Offline zenndog
« Reply #11 on: April 17, 2012, 01:03:41 PM »
I could modify the post above but I will leave my snarky post. It is a 1928 ford right? It was in a different part of the rulebook.
Offline n49racer
  • Faster Faster
« Reply #12 on: April 17, 2012, 01:18:13 PM »
We used a 28/29 body with a 32 grill. I assume you could us any Ford grill. I still don't understand the 530sq.in. as I don't think the 32 grill even fits that requirement. We used an automatic in the truck because we found it just too hard to get a standard in there with all the associated hardware and roll cage. Plus we had a sponsor for the automatics.
I believe the T body would be much more aero as there is no step at the cowl and no posts. The body is fisically smaller. We looked at putting a 26/27 body on the truck chassis but I decided the new car direction was the better way to go. You never know but the truck may see the salt again as racer or as a street car left as is less the cage.
B/STR  209.97 best
2 club member 2012
Offline maguromic
« Reply #13 on: April 17, 2012, 01:22:12 PM »
I believe the 530 minimum is bases on a model A grill, a  32 is more than that.  Tony
« Reply #14 on: April 17, 2012, 02:31:21 PM »
The T body is physically smaller.  That's part of the problem in Street Roadster.  The driver's compartment is both shorter and lower.  And the hood is shorter.  All make the driver stick out in the wind a great deal more, al least with a V-8 motor.  The 530" is based on a 28-9.  But you can use the stock T if you're using a T body.  Read the book, then read it again.
