Author Topic: Bonneville Build 2012 124 inch  (Read 37600 times)
Offline 55chevr
Re: Bonneville Build 2012 124 inch
« Reply #15 on: May 13, 2012, 11:12:50 PM »
Like the swingarm --- is it going to be long enough?
Offline racer
  • Impound 2009. sweetest spot at Bonneville.
« Reply #16 on: May 14, 2012, 01:23:24 AM »
Thanks Joe,
We certainly hope so.....
Only time and the salt will tell.
Fun project that may be street friendly as well.
« Last Edit: May 14, 2012, 01:27:57 AM by racer »
Ray C Wheeler
Offline racer
« Reply #17 on: May 24, 2012, 02:02:34 PM »
Progress is being made......
Ray C Wheeler
Offline racer
« Reply #18 on: May 24, 2012, 02:03:43 PM »
Progress.....
Ray C Wheeler
Offline racer
« Reply #19 on: May 24, 2012, 02:04:28 PM »
Progress.....
Ray C Wheeler
Offline racer
« Reply #20 on: May 24, 2012, 02:06:27 PM »
Progress....
Mono shock mount.....
Ray C Wheeler
Offline racer
« Reply #21 on: May 24, 2012, 02:09:25 PM »
Front motor mounts, drilled and tapped for Turbo mounting.....
Ray C Wheeler
Offline racer
« Reply #22 on: May 24, 2012, 02:10:13 PM »
Front Motor mount.....
Ray C Wheeler
Offline Moxnix
  • Zufrieden mit Mir.
    • Speed Bumps on the Road to Perdition
« Reply #23 on: May 24, 2012, 02:31:09 PM »
Are you intending to add weight to the chassis?
I'm looking forward to see your speeds.  Cheers,
Offline racer
« Reply #24 on: May 24, 2012, 02:36:10 PM »
Thanks.....
We're fabricating 1/4 inch steel plates that will mount between frame rails directly under motor and transmission. Room for at least 4 possible 5....
Tough time sleeping lately................ Imagine that.....
Salt fever is highly addictive.
Ray C Wheeler
Offline racer
« Reply #25 on: May 24, 2012, 09:43:58 PM »
5/25/ Thursday end of the day...
Progress....
Ray C Wheeler
« Reply #26 on: May 25, 2012, 12:23:17 AM »
Ray, the upper mount for the rear shock will experience a lot of load.  Will the tube twist that it is welded to?
That is a nice build.  Lots of good thinking and craftsmanship.
Offline racer
« Reply #27 on: May 25, 2012, 12:31:52 AM »
Still in progress.
Thanks for the good eye. Will check it out.
Ray
Ray C Wheeler
Offline firemanjim
« Reply #28 on: May 25, 2012, 01:35:10 AM »
Looks like Suzuki rear-----
Offline racer
« Reply #29 on: May 25, 2012, 01:44:41 AM »
Busa suspension axel to axel.
We are not trying to re-invent the wheel.
Just use the best of the best.
Headlights and a tail light after Bonneville'
Ray C Wheeler
