Author Topic: New Bike Frame Project  (Read 73285 times)
Offline 55chevr
Re: New Bike Frame Project
« Reply #150 on: May 08, 2015, 07:20:30 AM »
Bodywork is a future consideration.  Planning on running un-faired this year.
Offline saltwheels262
  • LTA 7/2013
« Reply #151 on: May 08, 2015, 01:38:19 PM »
that should be running well and very fast.
Bf262
ohio -    - 185.076 w/#684
lta 8/14  - 169.xxx. w/sw2
'16 -- 0 runs ; 0 events
                            - franey  8/2007
Offline bones
« Reply #152 on: May 11, 2015, 03:19:01 AM »
Hey Joe
  Which meetings will you be doing?
I have built a similar chassis for a Busa, less rake and is VERY stable.
I ran 205 at Gairdner this year and I recon the 1000 should be as fast and stable.
I would like to see it in the flesh.
I'll be at BMST and WoS
  cheers   Bones
Offline 55chevr
« Reply #153 on: May 11, 2015, 07:02:48 AM »
Still undecided about  BMST ...
Offline 55chevr
« Reply #154 on: August 19, 2015, 06:08:11 AM »
Ran the bike in LTA July race. First pass went easy thru gears shut off before the mile and coasted thru at 140.  Handling excellent but rear brake was not very effective.  Reworked it some and made a second pass.  A little stronger thru the gears and shut off at the mile for a 160 pass.  Rear brake no better.  Decided to err on the side of caution and re-engineer the brakes before running again.  The seat was too far aft and I decided to move it forward 5".  New rear caliper, brake line and pads seems to have solved the problem.  I also changed the front master cylinder for a Brembo off an F1 Yamaha. It has a stronger return spring which gives it less drag rolling resistance.
« Reply #155 on: August 19, 2015, 10:15:18 AM »
It looks really good Joe and it sounds like it performs as good as it looks. Well done.  :cheers: :cheers: :cheers:
Offline bak189
« Reply #156 on: August 19, 2015, 10:36:36 AM »
Joe.......Great looking bike...I really like the chassis/frame...............outstanding workmanship.......
Question authority.....always
Jessechop
« Reply #157 on: July 23, 2016, 07:18:07 AM »
Just to give everyone an update on this. Joe ran the bike last Sept to 187. However, the rigid design and 200+ hp was found to be unrideable. It kept unloading the rear tire.
A swing arm was added over the winter and I rode the bike at the Maine event last week. I took it very easy and ran a 145 first pass. A bit more throttle gave me a 181 on the second pass. The bike had much more in it and on the third pass  I encountered some motor issues and ended the event for this bike.
Offline 55chevr
« Reply #158 on: July 20, 2019, 02:25:20 PM »
Update on the 9516 bike.  Loring last week Nephew Cliff Daly rode to 175 with a stock ZX10r engine.  He is planning on spraying in the near future.  The addition of a rear swingarm has made a huge difference in handling.
« Reply #159 on: July 20, 2019, 03:07:38 PM »
Tell us dummies how that translates ? gas/fuel? displacement?
Offline 55chevr
« Reply #160 on: July 20, 2019, 05:44:56 PM »
AG1000 ? stock 2006 Kawasaki ZX10R engine.  The original frame was rigid but the surface was too rough and the tire would unload on the slightest bump.  Has a Soft Tail Harley shock with a Buell swingarm. Now actually quite stable.  The engine is tired and a stronger engine is in work using a Bob Carpenter head. The original design was done by "Oz" from England. His design used a Honda 1000 engine.  He shared his notes, construction photos and design measurements which made the fabrication fairly easy.
